Author Topic: MOT fail ?  (Read 5305 times)
Re: MOT fail ?
« Reply #15 on: 01 March 2017, 12:20:55 »
Expect an advisory for it, but not a testable item.  :y
Re: MOT fail ?
« Reply #16 on: 01 March 2017, 12:50:49 »
Blimey, not seen one of those for a long time, think the last one was on a 2.3 Diesel Carlton.
From memory you need to be careful with fitting as if you get the actuator arm in the wrong place inside the pump unit  then it can cause the revs to go through the roof (get something ready to bung over the inlet when first starting!)
The likes of Peter Slater are good for such parts.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: MOT fail ?
« Reply #17 on: 01 March 2017, 13:35:30 »
Its attached to a 1990 2.5, 5 cylinder Merc engine. Not a common sight these days.  :)
Will bear your advice in mind when fitting and check out Peter Slater, thanks.  :y
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: MOT fail ?
« Reply #18 on: 01 March 2017, 16:31:47 »
0928400271 is this the part number. Taken from an ebay seller but its in america
Migv6 le Frog Fan
Re: MOT fail ?
« Reply #19 on: 01 March 2017, 18:02:48 »
Will check that out. Thanks.  :y
