Author Topic: Facelift wiring diagrams - TIS?  (Read 2842 times)
  • Auckland
    • Mazda MPV
« on: 28 February 2017, 13:40:37 »
Am I correct in thinking that the only way of getting up to date (or up to 2003 at least ::)) wiring diagrams for a facelift Omega is to get hold of a TIS DVD and install it on an old 32 bit windows PC?
(I think that might be three separate questions :-\)
Re: Facelift wiring diagrams - TIS?
« Reply #1 on: 28 February 2017, 13:43:06 »
If Kevin can't help, I almost certainly can :y
  • Auckland
    • Mazda MPV
« Reply #2 on: 28 February 2017, 13:57:21 »
I need to do a continuity check on the wiring between the MAF and the engine ECU on the Project MV6.
I would also like to check which pin of the OBD socket connects to the k-line for the SRS ECU to see if that is the reason that ScanMyOpel is unable to connect to it (not urgent that one).
« Reply #3 on: 28 February 2017, 14:04:22 »
Will have a gander when back from MoT :y
« Reply #4 on: 28 February 2017, 14:10:41 »
PM sent. :y
  • Auckland
    • Mazda MPV
« Reply #5 on: 28 February 2017, 15:09:50 »
PM sent. :y
Excellent :y
Thanks Kevin.
Last things first ::) I can see that the airbag diag connects to pin 12, which is also the pin used by the ABS. ScanMyOpel can connect to the ABS so there is no point in me connecting more pins in attempt to get it to connect. (I don't have a pressing need to connect to the airbag ECU but I like the idea of being able to clear an airbag code if the need arose).
Next task is to identify pins 57, 51 & 56 at the ECM connector X86 and test the continuity of the wiring.
« Reply #6 on: 28 February 2017, 16:04:12 »
The ECM connector has small pin numbers at the end of each row of pins so you can count along to the pin required. They are quite high density so a bit fiddly.
