Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Adding sump drain plug kit to Auto trans fluid sumps  (Read 21266 times)
Re: Adding sump drain plug kit to Auto trans fluid sumps
« Reply #60 on: 08 March 2017, 17:08:23 »
Fair enough. That may be enough motivation to do it! ATF in the hair is not fun!
I was thinking about welding a section of thicker steel to the sump, then drilling and tapping it and fitting a normal style sump drain plug.
It would have to go on the side, not the bottom, of the sumps, if my AR35 sumps are anything to go by.  Having lost a (engine) sump plug before at speed, due to it hanging lower than anything else, I'm quite wary now....
« Reply #61 on: 08 March 2017, 17:23:20 »
Indeed. Another reason why I haven't bothered.
rds
« Reply #62 on: 08 March 2017, 18:00:27 »
I lost my hair a way back but still don't want the stuff everywhere!
Yes, I was wondering how well the drain kit would work out - I hope to get to it soon. I also thought of the welding and tapping route but figured this would be a quicker way. I am hoping there is plenty of latitude in positioning, which may not be the case if the filter has little clearance below it.
Side or back drain position will help in draining when car is jacked up; but i don't think I see that the drain will hang down much further than the exhaust clamps. Having said that, i got into the bad habit of straddling the pillow type speed humps and it won't take much to tear...
cheers
RDS
« Last Edit: 08 March 2017, 18:03:28 by rds »
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #63 on: 08 March 2017, 20:11:31 »
If you can find a Senny Auto with an AR35 in a scrappy, the rear sump has a drain plug rear RH corner. :y
rds
« Reply #64 on: 10 March 2017, 15:10:10 »
Hello again
a Senator eh? Shame that accessible scrappies are few and far between these days...
A "parts interchange list" for the Omega would be a great asset - is there one?
cheers
RDS
Pages: 1 2 3 4 [5]  All   Go Up
