Pages: 1 [2] 3  All   Go Down
Author Topic: interesting oil filter  (Read 13965 times)
citroenguy
  • Sweden
    • 2005 Citroën C5 2.0SX
Re: interesting oil filter
« Reply #15 on: 02 March 2017, 20:30:59 »
Turbo gone? Whining?
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
serek
  • huntingdon
    • 3.2 mv6
« Reply #16 on: 02 March 2017, 20:34:15 »
turbo ok bit play but nothing major
but when we pull sump off there was some foreign objects at the bottom , maybe left from engine repair
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #17 on: 03 March 2017, 19:25:38 »
French? ::)
citroenguy
  • Sweden
« Reply #18 on: 03 March 2017, 19:53:13 »
French? ::)
Maby they were pieces of a baguette  ;D
124k on the C5
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #19 on: 03 March 2017, 20:19:40 »
French? ::)
HAHAHAHA PMSL   ;D ;D ;D ;D
Omegatitis : [in remission]
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #20 on: 04 March 2017, 10:03:12 »
At lest I think it's the 2.0 :-\
2.0hdi is almost bomb proof if maintained properly
Then wtf am I thinking of 😂
There's a pug engine where it runs too hot and sludges up the oil. That coupled with a tiny gauze filter in the turbo inlet line that has to be modified (or completely removed). They blow turbos all the time and still do even if u follow the exhaustive turbo replacement instructions?
RIP Paul Lovejoy
citroenguy
  • Sweden
« Reply #21 on: 04 March 2017, 12:29:11 »
You are thinking about the 1.6 HDI/TDCi (the one in this thread), the early iterations of this engine are sensitive to oil changes. ABSOLUTE MAX 12000miles intervals or it probably will gum up the oil feed line and bugger the turbo. And if you don't remove that gauze filter and change the oil lines the new turbo will be fooked soon. I believe one of the reasons is the relatively low oil capacity of 3.75 L. But idiotic service intervals past 12k is probably the main issue..
124k on the C5
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #22 on: 04 March 2017, 16:00:09 »
Lots of VAG kit on longlife  20k intervals die early too :-X
other rides
Webby the Bear
  • Northampton
« Reply #23 on: 04 March 2017, 20:04:23 »
Thanks for clearing that up  :y
We won't even touch turbo replacements on these. You get a two page document with a new turbo on all the things you have to do to maintain the warranty. I'll see if I can find it...
RIP Paul Lovejoy
citroenguy
  • Sweden
« Reply #24 on: 04 March 2017, 20:10:53 »
Just as a side note the early 1.6 HDi will go for along time if serviced.. I've seen ones with 150k miles on the original turbo.
124k on the C5
henryd
  • west cornwall
« Reply #25 on: 04 March 2017, 21:13:47 »
I still think the old 20hdi is a harder engine,seen several with way past 200k miles and still good :y
other rides
citroenguy
  • Sweden
« Reply #26 on: 04 March 2017, 21:34:06 »
+1/agreed
124k on the C5
serek
  • huntingdon
    • 3.2 mv6
« Reply #27 on: 04 March 2017, 21:53:48 »
French? ::)
why you picking on Me ?????? ;D ;D ;D ;D
serek
  • huntingdon
    • 3.2 mv6
« Reply #28 on: 04 March 2017, 21:54:59 »
French? ::)
maybe if baguette can turn in to solid metal  :P :P :P
serek
  • huntingdon
    • 3.2 mv6
« Reply #29 on: 04 March 2017, 22:08:31 »
if you do oil change every 10K ish with full synt oil and after 100K drop sump off and clean pick up pipe they do last  :y :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.014 seconds with 22 queries.
