tie-rod tapper spliting
Started by Bojan, 03 March 2017, 07:25:41
Note to the BMWists, budget for a new hub carrier when the inserts come out :-X
Migv6 le Frog Fan
Quote from: RumpelStiltSkin on 03 March 2017, 08:25:03
I use a splitter for TREs (the type with bolt, not fork type), and 2 hammers for idler etc
Same here. Works well for me.
Migv6 le Frog Fan
Quote from: RumpelStiltSkin on 03 March 2017, 08:47:51
Quote from: Bojan on 03 March 2017, 08:44:06
I'm fitting new links.
So damage to the thread or boots is not a problem.
BTW, how heavy hammers do you use?
I'll probably taka 0,5kg.
I use a pair of 4lb (approx 2kg) as there is no access for Sammy.  :y
Bojan
Feedback: did it whit two hammers for outside rod; hammere and crowbar for inner rod.
Outside were dead easy - it took a two sharp blows per side.
Inner ones were tricky - not enough place to swing a hammer nicely. In the end, i've backed up thh central rod with ceowbar, and hammered out the tie rod.
Bigron
I'm glad you've got it done, but without "hammering the point" (groan?), you don't need to take an almighty swing at it; if you have a really heavy (minimum 3-4 pounds)  hammer as an anvil behind the joint, a few rapid, sharp taps will pop the joint.
Ron.
