Author Topic: Battlebus performance, thankyou Marks DTM Calib  (Read 18983 times)
X30XE
  • UK
    • 740i,728i,S320 & Disco
Re: Battlebus performance, thankyou Marks DTM Calib
« Reply #15 on: 11 March 2017, 18:47:28 »
I bet!
For anyone else wondering...  Hells teeth!! ....
Omegatitis : [in remission]
« Reply #16 on: 12 March 2017, 08:57:38 »
So .... just what was that crap?  :-\
« Reply #17 on: 12 March 2017, 09:29:45 »
Oil, oil fumes and dust.
  • Auckland
    • Mazda MPV
« Reply #18 on: 12 March 2017, 09:37:45 »
Deisel poo
    • 530D M Sport, 330i Coupe
« Reply #19 on: 12 March 2017, 09:43:41 »
Last one I had was cleaned with paint stripper, come to think of it I think I left that with you.
X30XE
  • UK
« Reply #20 on: 12 March 2017, 10:34:48 »
EGR soot - fine on it's own
Oil breathers/turbo oil - fine on their own
combine the two... SCHMOOOOOO!!!
« Reply #21 on: 12 March 2017, 10:58:58 »
Yes, was going to fit that (identical between Omega and Zafira), but swirl flap actuator had gone faulty.  Still, the cleaning only took about an hours :)
Having yours to hand did help us find where the bolts were though ;D
« Reply #22 on: 12 March 2017, 11:04:17 »
I have never seen anything that bad, I am still somewhat suspicious of the MAF
As was I, but I think first port of call today is to see why the turbo ain't provide much boost at 3000rpm when I plugged in Tech2 earlier ::)
« Reply #23 on: 12 March 2017, 18:01:31 »
Wastegate actuator freed off today, in the warm, dry confines of chrisgixer's garage (thanks chrisgixer, and thanks to Mrs CG for breakkie, complete with smiley faces, that made my day :D).
Boost readings 'better' on standstill Tech2 tests, but still poor.
Swapped boost pressure sensor for one that VXL V6 gave me, readings marginally better, but still poor (1.3bar at 3k rpm).
Gave it a run, miles, miles better now the turbo is able to spool up at lower revs.  Quite drivable in fact, but I reckon still a bit down on power.
How long does the smell of split diesel around the engine last, as it still reeks of the stuff - while I had undertray off earlier, did try to mop up all that I could see.
« Reply #24 on: 12 March 2017, 18:03:06 »
Well done  :y
To answer your last, ages ;)
« Reply #25 on: 12 March 2017, 18:17:44 »
Well done  :y
Definable? 50 miles? 100 miles, 500 miles?
« Reply #26 on: 12 March 2017, 18:24:56 »
I would er on the side of 1-500...
« Reply #27 on: 12 March 2017, 18:31:18 »
Ta. I think that SWMBO's Astra must've had similar problems though the car was written off before I got to the bottom of it.
« Reply #28 on: 12 March 2017, 18:34:51 »
OK, ta, I'll try to use it all week for work, that will rack up most of those 500 miles :y
I need to it to be good for Saturday :)
« Reply #29 on: 12 March 2017, 19:42:40 »
Somewhere I have a DTi MAF, if I can find it I'll be passing yours a couple of times this week.
Pages: 1 [2] 3 4  All   Go Up
