Learning to rebuild an engine
Started by Viral_Jim, 13 March 2017, 13:37:21
Quote from: 78bex on 14 March 2017, 01:50:54
Figuring out why a simple motor doesn`t work is a good stepping stone to the bigger stuff
I think the first engine I tried to strip & rebuild was a 4 stroke Suffolk Punch L/mower engine
Made loads of mistakes & broke one of the piston rings & forgot to keep tabs of what went where.   I learnt a lot from that project.
I`ve tackled outboard motors & motor cycle engines.
now I can`t stand seeing ppl binning petrol strimmers & mowers at the tip  ;D
Yep, I was about to say that an old mower would be a good place to start. They are cheap / free as most consumers buy a mower, never service it, then bin it or chuck it on freecycle the instant it fails to start. The principles are exactly the same as for a larger car engine yet you can play with very little cost.
I found it very interesting and satisfying fixing the Briggs & Stratton engine on the lawn power, stripping it down and cleaning the carbs etc.
The joy at in then firing straight back up  8) (once i realised I had to re-attach the spark plug lead)
