Pages: 1 2 [3]  All   Go Down
Author Topic: 3l V6 coffee table  (Read 11312 times)
LC0112G
  • Online Online
Re: 3l V6 coffee table
« Reply #30 on: 22 March 2017, 09:45:54 »
I can't help thinking that if you stub your toe on that it's gonna smart a bit more than it does with a normal wooden coffee table.
However, if you're going do it properly ring around a few plating places - chrome plating isn't that expensive, and they'll have to thoroughly clean and chemically dip the block first to do that saving you all the aggro of cleaning it up.
Con rods bolted into head bolt holes looks like the way to go. Pistons mounted to rods with normal gudgeon/wrist pins, and then all you've got to sort out is fixing the glass top to the piston crowns.
« Reply #31 on: 22 March 2017, 12:34:16 »
I should imagine the removal men would be a bit put out if you ever moved house as well. ;D
EMD
  • Noofhampton
    • 95t
« Reply #32 on: 22 March 2017, 13:43:38 »
Chrome in a spray can , comes up really good if you do all the prep work  :y
Omegatitis
« Reply #33 on: 22 March 2017, 13:45:21 »
Errrr...no. If it's being properly chromed then it will be properly dipped. You can't get rid of enough crap to get a decent finish any other way.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #34 on: 22 March 2017, 20:38:21 »
Got the wire wheel out today  ::)
Did that, hit it with a load of brake cleaner, got the blow gun and got rid of the spiders, then wire wheeled it again. Very pleased with the results but there are quite a few patches the wheel couldnt get to.
The plan now is to break out the due grinder with a light sanding bit in to all the nooks n crannies.
I then think I'll smash it with the rust removal liquid.
Then just keep going til it's clean.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #35 on: 26 March 2017, 11:41:57 »
The block is almost ready for painting thanks to the apprentice  ;D ;D ;D
RIP Paul Lovejoy
« Reply #36 on: 27 March 2017, 06:48:50 »
Can you liberate the spin on conversion before painting :-*
Best not get the apprentice to do it though... he doesn't look particularly enamoured with his lot in that picture ;)
Webby the Bear
  • Northampton
« Reply #37 on: 27 March 2017, 15:05:37 »
Al I had the same thought myself. I assume you mean the threaded portion that the filter screws on to? I blindly stuck an Allen in there but it didn't catch. I'll get a torch in there n see what's what
RIP Paul Lovejoy
« Reply #38 on: 27 March 2017, 15:06:38 »
14mm hex :y
Webby the Bear
  • Northampton
« Reply #39 on: 27 March 2017, 19:01:41 »
Cheers mate I'm sure it'll come out. Do u want it if I do?
RIP Paul Lovejoy
« Reply #40 on: 27 March 2017, 19:07:49 »
Might come in handy* ;)
* I can here Nick Ws voice from here...  :D
Webby the Bear
  • Northampton
« Reply #41 on: 27 March 2017, 19:13:07 »
Well I don't plan on converting mine so feel free. Postage will be £287.34 👍😂
RIP Paul Lovejoy
« Reply #42 on: 27 March 2017, 19:13:54 »
Is that the pre or post brexit price :D
Pages: 1 2 [3]  All   Go Up
