Author Topic: Head gasket kit? Anyone bought this?  (Read 3270 times)
Re: Head gasket kit? Anyone bought this?
« Reply #1 on: 20 March 2017, 08:19:42 »
Not used that set. Remind us, why do you need a head set? The HG on the 3.2 is pretty robust... Or is this the car with the bent valves? :-\
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
« Reply #2 on: 20 March 2017, 09:20:13 »
Yeah motor with bent valves. I'm only just getting round to it now. Heads are out and ready to take the valves out.
Drive 'er like yer late for mass!!
« Reply #3 on: 20 March 2017, 09:47:59 »
Fair enough. Not teaching you to suck eggs but make sure you check it all, including the guides, thoroughly.
I would suggest not skimping... Mr DTM gives good advice on these things ;)
horsecow
  • Omagh
« Reply #4 on: 20 March 2017, 09:53:27 »
I'm kind of leaning towards the more expensive option tbh. I wouldn't buy the cheaper one unless someone can advise me that it's so a similar quality.
Once I get the heads opened up I'll be giving them a thorough going over and I've already got another set lined up just incase I need them. Getting spare time to do it in is the hardest bit!
« Reply #5 on: 20 March 2017, 10:02:25 »
Used that supplier for years without any significant issues at all.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Hoof'land storeman.
horsecow
  • Omagh
« Reply #7 on: 20 March 2017, 10:26:38 »
Thanks Marks Dtm. Peace of mind knowing that's someone else has used it.
Biggriffin the extra £20 is for the head bolts.
« Reply #8 on: 20 March 2017, 11:12:25 »
Just a few pointers (now I have a few more minutes to type):
1) The exhaust manifold gaskets in the kit are utter rubbish, the correct ones are a multilayer steel gasket so either re-use the old ones if they are ok or seek out the correct ones.
2) Re-use the crank shaft seals, they will be fine if fitted correctly.
3) Don't bother with the new inlet gaskets, there pretty rubbish and the originals will be fine.
4) The cam cover gaskets can be a bit hit and miss.
5) I did have a one off bad experience with the head bolts, three snapped but, they happily replaced them and supplied new head gaskets to.
With the heads off its the perfect opportunity to re-seal the oil cooler cover to block plate without risking knackering the threads to the oil cooler.
horsecow
  • Omagh
« Reply #9 on: 20 March 2017, 12:04:01 »
Once again Marks Dtm thanks. All advice is much appreciated, this is all new to me, I've not done anything like this b4 but the car was bought as a hobby and I'm enjoying it so far. Putting it all back together could be a different story :-[
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #10 on: 22 March 2017, 19:51:56 »
I bought a Reinz head set and bolts from AllGermanParts for £115 early last year.
horsecow
  • Omagh
« Reply #11 on: 05 April 2017, 20:17:18 »
Okay guys, waiting on a final price for the gasket set but I picked up 2 replacement heads this evening. The heads that I took out of the motor were stamped 2b and 2c. The replacements are stamped 1c and 1d, is this going to be a problem?
