Author Topic: bosch extending headlamp wash jet doofer  (Read 6042 times)
annihilator
  • Wirral
    • Omega Tourer V6
« on: 20 March 2017, 14:38:52 »
anyone successfully unblocked one of these blighters (90510268) have tried soaking it in various liquids over several weeks but no joy.Can't see a way of dismantling it without destruction so any suggestions welcome.(needed for mot)
will post a wanted if anyone has a known working replacement.
Cheers John.
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Re: bosch extending headlamp wash jet doofer
« Reply #1 on: 21 March 2017, 04:48:34 »
i did one but you need to back flush it. with air gun, or could use air in a can if its got good pressure. but soak it in strong vinegar. might take a few goes but it did work for me.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 21 March 2017, 18:48:31 »
I've spoken to a couple of mot testers,and they tell me headlamp washers are not a mot failure item.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 21 March 2017, 19:04:57 »
They are a requirement if the car has HIDs, and so non working ones are a failure. That's why mine failed about 3 weeks ago.
BazaJT
« Reply #4 on: 21 March 2017, 21:43:02 »
Would a car with the "pop up" type washers have HID's?I know the pfl Elite I had some years ago had this type of washer,but didn't have HIDs and the nozzle part[the bit that sits above the bumper]could be pulled off the extending tube part.Whereas the f/l Elite I now have has HIDs but the washers don't "pop up.
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #5 on: 22 March 2017, 09:01:17 »
They do I've got one hence the question,as far as I know all m/fl elites have Hid. :y
John
« Reply #6 on: 22 March 2017, 10:01:27 »
They do I've got one hence the question,as far as I know ALL Elites have Xenons with washers. :y
John
Fixed.
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #7 on: 22 March 2017, 14:42:52 »
I did the same when the headlamp washers seemed not to be working, and the tester stated mine, a 2003 3.2 Elite would not fail if they were not working. It was not a MOT failure issue. :)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #8 on: 22 March 2017, 15:46:37 »
Why don,t we have a MOT failure for dirty/unreadable rear no. plates? Or, fit a washer on that as well :-X
« Reply #9 on: 22 March 2017, 16:01:53 »
Oops! That reminds me. Where's me cloth? :-[
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #10 on: 22 March 2017, 16:22:49 »
Fixed.
correct but m/fl are not fixed in the bumper like facelifts but I'll modify mine so they soon will be.
John.
« Reply #11 on: 22 March 2017, 19:15:32 »
John
Fixed.
Incorrect Al.
No pre MFL cars have HIDs. PFL Elites do have washers though.
MFL MV6 and Elites have HIDs with washers.
FL MV6, CDX and Elites have HIDs with washers.
« Reply #12 on: 22 March 2017, 22:11:46 »
Were xenon lights not invented pre '97 then ???
« Reply #13 on: 22 March 2017, 23:04:07 »
Matters not, HIDs and Xenon are completely and totaly different ....
Xenon is a gas, and can be in a bulb of any voltage, just like sodium, helium, halogen etc etc etc that will prevent an incandescent light (glowing filament) from oxidising and going "pop" .. they are still filament bulbs.  The use of xenon gas as a protector allows the filament to run hotter thus providing more white light ... the filament is "white hot"
HID's are High Intensity Discharge lights that work off a high energy (voltage) to "strike" an electric arc that gives off the light, the fact that the gas in the "bulb" might be xenon is by-the-by but is what causes the confusion.
So you can have xenon bulbs that work off 12 volt and the gas just protects the glowing wire, or xenon HIDs where the gas is an inert vehicle to contain the electric arc running at thousands of volts and help form the "plasma" field that makes the light
HTH
EDIT
For those who wish to understand better ...
https://en.wikipedia.org/wiki/High-intensity_discharge_lamp   :)
« Last Edit: 22 March 2017, 23:20:00 by Entwood »
« Reply #14 on: 23 March 2017, 04:16:52 »
Kind of muddying the waters given that they're essentially the same thing on the Omega ::) the choice being vanilla halogen or xenon with ballasts...
Page created in 0.028 seconds with 20 queries.
