MPH per 1000 RPM?
Started by Field Marshal Dr. Opti, 21 March 2017, 15:40:09
the alarming man
bet your glad you started this  ;D
Quote from: Doctor Opti on 21 March 2017, 16:14:41
...or is it 3.14 times the radius (14 inches) rather than diameter?
My brain is starting to hurt. ::)
Circumference = 2piR = 2 x 3.14159 x radius
which is the same as piD or 3.14159 x diameter
or if you wish to be more accurate ..
3.14159265358979323846264338327950288419716939937510 x diameter
Circumference is 2Pir, so 2x(3.142x14) ;)
2boxerdogs
All far too technical for me , will go back to reading my book.
Bigron
That was just an approximation to Pi, Nige - you need a few more decimal places for true accuracy; it goes on to infinity, apparently.
May we both live long enough..... ;D :y
Ron.
Quote from: jimmy944 on 21 March 2017, 16:13:34
This is a bit American-acised, however should work
http://www.crawlpedia.com/rpm_gear_calculator.htm
Thanks, jimmy.
The accurate parts. Final drive 2.56 and gear ratio 0.667. :y
The guesswork, Wheel and tyre 28 inches in diameter.
This combination gives me 48.8 MPH for each 1000 RPM.
Quote from: Bigron on 21 March 2017, 17:07:08
Ron.
"Pi has been calculated to over one trillion digits beyond its decimal point. As an irrational and transcendental number, it will continue infinitely without repetition or pattern."
.. perhaps we should start counting now Ron ......  :)
Quote from: Bigron on 21 March 2017, 16:08:46
Isn't it in the manual? From memory, for a 2.6 FL auto saloon in locked top it's 28 mph per 1000 rpm.
Ron.
Sounds about right, Ron.
100 MPH was slightly less than 4000 RPM in my 2.6 auto.
Quote from: Entwood on 21 March 2017, 17:31:37
Ron.
Yes.....apparently the sun has only enough energy to last another 4 billion years. :)
Migv6 le Frog Fan
My Chevette HS was 18.9 mph / 1000 rpm in top gear.This could be why it only did 18mpg.  ;D
Quote from: Migv6 on 21 March 2017, 18:22:57
With a torquey 2.3 litre lump top gear acceleration would have been good though. :y
Bigron
Is that an American billion or a proper on, Dr Opti? It's important to know how much to worry..... :-\
Ron.
Quote from: Bigron on 21 March 2017, 18:51:01
Ron.
Well Ron, a billion has always been a thousand million when I do the maths (or should that be 'math' for our cousins from the former British colonies) ;D
Bigron
That's an American billion - OURS is a million million.
There is an English term for a thousand million - a Milliard - but few people use it as it's so close to million.
Why not avoid confusion and follow scientific practice (and computing terminology) use Mega, Giga, Tera, etc?
Ron.
Quote from: Bigron on 21 March 2017, 19:02:13
Ron.
There is no confusion, Ron, everyone uses a thousand million for a billion now.
