Author Topic: Bending brake pipes ?  (Read 12430 times)
EMD
  • Noofhampton
    • 95t
Re: Bending brake pipes ?
« Reply #15 on: 29 March 2017, 18:20:52 »
*edit. Paw singular  ::)
Your doing a great job steve ... have you had a go with a plasma cutter yet  ;)
Ive searched in the shed for the new fuel line for hours then seen it hanging up in a place i thought i would see it easily  ::) Oh and found the special key to undo the hubcaps  ;D Really ought to drop the fuel tank to gain better access to the brake line  :( I shall try the socket method first to shape the bends and see how it goes  :y
Omegatitis
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 29 March 2017, 21:34:33 »
Lads, I got over it a long time ago!  ;D but thanks for the nice comments  :)
Never made fuel lines before but for brake lines get the old one on the floor and shape around the with your hands. I'll admit I've made some not very pretty ones  ;D but function over form in this case  :)
RIP Paul Lovejoy
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #17 on: 29 March 2017, 22:28:42 »
The other option is buy pre made ones.
I haven't researched this. However I replaced a brake line on a Renault Megan last week and as the line was an integral part of the flexi I had to get it from Renault (well Allen ford actually... they can get French parts) and the entire line from nsr calliper, to flexi, then pipe to a fitting on the offside was £24 plus the vat. So potentially that's an option. But obviously that's only one example. I've no idea how much certain sections would be elsewhere or if they're even available. Worth a phone call though imo
Hth Steve  :y
the first one that I made was for a scenic if I remember right I had to reuse the original ends
« Reply #18 on: 30 March 2017, 13:20:51 »
The potential problem with pre-formed brake pipes is that they were designed to be fitted on a car on a production line .... there's  now a variety of stuff in the way  ;)
« Reply #19 on: 30 March 2017, 13:49:48 »
The Omega isn't too bad, but on a car with a proper subframe, Bmw/Mercedes to name but two, there's no point changing the plumbing unless the car is a keeper as it will inevitably mean dropping the subframe. At which point you might as well change all the bushes etc...
Webby the Bear
  • Northampton
« Reply #20 on: 30 March 2017, 19:05:53 »
Oh absolutely. Was just thinking of another option for emd. The Megan's one I mentioned was awesome. Off. On. And looked better than anything I could make  ;D
RIP Paul Lovejoy
EMD
  • Noofhampton
    • 95t
« Reply #21 on: 30 March 2017, 19:59:19 »
The fuel pipe i removed looked ok rubbed down and greased but on inspection the pipe was wafer thin and snapped with ease  :o
Omegatitis
