Diesel additive
Started by JDX, 01 April 2017, 12:21:53
Quote from: biggriffin on 02 April 2017, 20:02:50
Pump would, give up, then injectors' block, O dpf would be knackered.
According to OOF wisdom that's what happens every 1000 miles regardless of what you run a modern diesel on ;)
Quote from: aaronjb on 03 April 2017, 08:54:39
That generous!  :o  ;D
But it is correct for a modern diesel if running on vegetable oil as is considering the diesel magic trick on a common rail setup..
biggriffin
Quote from: Marks DTM Calib on 03 April 2017, 09:55:00
Now would that be, the fill, the filter and housing with said product and start.
Hoof'land storeman.
Indeed it would, takes out the high pressure pump  :y
tigers_gonads
Quote from: Jimbob on 01 April 2017, 16:51:42
I chuck 250ml of 2 stroke in per tankful.
Definately makes it quieter / smoother and possibly a little more mpg too,
We do similar to my lads Corsa cdti but every second tankful
tigers_gonads
Quote from: Migv6 on 02 April 2017, 17:07:02
That and smellier.  :y ;D
Its currently running on a very sweet smelling Tandoori flavoured oil. Makes people in cars behind me hungry apparently.  ;D
;D
I used to have a customer who owned a kebab shop who was quite happy to let me take the waste oil.
Used to stick it on the roof of the shed in the sun for a month until the oil and fat had separated then it went into the tank of the panzer (my old 2.5 td estate)
I was sat at some traffic lights one day when a couple of traffic coppers pulled up along side of me, tapped on the window and asked for fish and chips twice before driving off laughing  ::)
Got to admit, I shit myself because it was sign written up at the time  8)
VAT avoidance and all that  ;D
Migv6 le Frog Fan
Nothing to worry about. Its perfectly legal, as long as you don't use more than 2500 L per year.  ;)
