CD Player Cleaner
Started by Lizzie Zoom, 06 April 2017, 17:18:30
Webby the Bear
Lizzie what does one do with this product? Is it a spray you spray in? I've got the exact same issue.
RIP Paul Lovejoy
Lizzie Zoom
Quote from: Webby the Bear on 17 April 2017, 19:48:31
It is a disc with one track with a line of tiny brushes. You put the disc in the changer in position 1 and it goes through track by track a series of diagnostic checks on your whole system, but one track is for cleaning.  It has worked well for me as it was so simple to use.  :y
Webby the Bear
Quote from: Lizzie Zoom on 17 April 2017, 20:08:57
Excellent. I'll give this a go.  :y cheers lz
RIP Paul Lovejoy
Having used similar before, just be aware that somethings the ones with the brushes make things worse.
Lizzie Zoom
Quote from: RumpelStiltSkin on 18 April 2017, 16:10:19
Make things worse?  How can it be worse than the unit not recognising any CD's inserted, let alone playing them? ;D ;D ;D ;D ;D ;)
A lens cleaner cannot repair an oppsed lens. Not exactly rocket science... or news ::)
http://www.omegaowners.com/forum/index.php?topic=90496.0 :-X
Lizzie Zoom
Quote from: Doctor Gollum on 18 April 2017, 18:53:15
No doubt that is the case, but my problem was as described above in my last post and the cleaner disc sorted it. ;)
Webby Bear says he has the same problem, so hopefully it will work for him too ;)
Quote from: Lizzie Zoom on 18 April 2017, 17:14:16
In most cases, both CD Changers fitted to Omegas (CDC2 and CDC3) start to get fussy on discs and temperature, but other discs/temperatures are fine.
The brush based systems are a bit barbaric, and can easily damage the lens coating or even the carrier completely.  The CDC3 (facelift) is particularly fragile.
Although in virtually 100% of all CDC3 changers not reading discs, its the focusing coils that are shot.  Unless the car was owned by a heavy smoker, the CDC3 is not a particularly dusty envirnoment, and every single one I've taken apart that wasn't owned by a smoker (as these are really obvious) have been pretty tidy inside.
At best, a brush system can only ever really be useful in removing specs of dust (would destroy the lens in a couple of rotations if it were more thorough), and IME, dust doesn't collect around the lens.
I'm really glad its (temporarily ;)) worked for you LZ :y, but the only method I could ever recommend to CDC3 owners in particular is stripdown and a proprietry lens cleaner...  ...or better still, laser replacement (fiddly, but not hard).
I probably should add I've stripped more CDC3's than I care to remember.  I need to take a photo of the shelves in my office here...  ...and this is the tiny amount I had left following the garage incident.
Lizzie Zoom
Quote from: RumpelStiltSkin on 19 April 2017, 09:16:18
That's it, give me good news and cheer me up..........not! ::) ;D ;D ;D ;)
jarqo1981
Hi! Can anyone advise me where I can buy discs ,,digital audio''? In shops I can see only ,,recordable'' verbatim, maxell etc. Regards  :D
