Author Topic: 2.6 V6 fuel injector  (Read 2629 times)
LaxeyStu
  • Bristol, United Kingdom
    • Omega 2.6 CD
« on: 06 April 2017, 18:43:46 »
My '02 2.6 V6 developed a misfire on the road, which shows up as cylinder 2 fuel injector and misfire on other cylinders. Originally EML light,  then engine symbol.  Occurs at all lower revs, rough running.  New injector quoted £270.
Seems fairly straightforward, or is there anything else this could be, or that I should do before getting the repair done?
Other than topping up, I haven't done any maintenance to the car yet (only just bought it).
Thank you.
Re: 2.6 V6 fuel injector
« Reply #1 on: 06 April 2017, 19:04:14 »
What was the ACTUAL code?  :)
« Last Edit: 06 April 2017, 19:17:44 by Doctor Gollum »
« Reply #2 on: 06 April 2017, 19:05:37 »
Far more likely to be HT related than an injector fault ;)
So, what were the codes ;)
LaxeyStu
    • Omega 2.6 CD
« Reply #3 on: 06 April 2017, 19:19:50 »
P0300, P0301, P0302, P0303 and P0202.
Thanks
« Reply #4 on: 06 April 2017, 19:48:18 »
Money loom fault as a)injectors on these are pretty bombproof and b) for that combination of missfire codes it is unlikely to be a water based HT issue...
0300 is pretty banal, but for water based HT issues it is more typical to see 0305/0306 first.
Pull the coil packs and look for signs of oil in the plug wells, especially cylinder 2. Then pull the plug and report back.
Also, any recent engine work?
LaxeyStu
    • Omega 2.6 CD
« Reply #5 on: 06 April 2017, 20:26:38 »
I don't know what work the car has had.  The MOT refers to oil leak and covers which I thought could be the rocker covers. I was vaguely aware of this issue with oil and coil packs.
The advice seems to have picked up that P0202 code and diagnosed fuel injector.
I would ask a garage to do what you are suggesting.
Thanks
« Reply #6 on: 06 April 2017, 20:43:24 »
You could also obtain a used injector, any would do, and plug it into each plug on the injector loom in turn  and ensure that the wiring is sound before condeming the injector itself.
  • Auckland
    • Mazda MPV
« Reply #7 on: 06 April 2017, 22:26:20 »
Thanks
If the coils have been swimming in oil due to leaking cam covers then the rubber boots on the coils will rot first and the insulation on the coils themselves may be scrap due to contact with the oil.
The cam cover seal leaks are generally caused by the crankcase breathers being blocked. Quite often we hear of people paying for the cam cover seals to be replaced only for them to fail again soon after because the breathers were not cleaned at the same time.
LaxeyStu
    • Omega 2.6 CD
« Reply #8 on: 14 April 2017, 14:42:16 »
Garage changed the coil pack and the issue has gone away.
Also, the fuel economy has noticably improved (38 vs 32mpg (!)) - possible warning of the issue?
Thanks for the help.
