Author Topic: who the devil sells distilled water ?  (Read 6678 times)
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« on: 10 April 2017, 20:58:13 »
Ok, Tesco,Halfords,boots,eurocarparts,cpa,homebase, asda etc etc all claim to sell it, but on closer scrutiny it turns out that what they actually sell is de-ionized water!
Has anyone bought any recently and if so where from as I am running out of options.
Thanks
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: who the devil sells distilled water ?
« Reply #1 on: 10 April 2017, 21:02:38 »
Both same, £1.50 in Tesco for 2.5L
Called battery top up in Halfords. £3.00 I think.
Or 20L from motor factors for about £12.00
Hoof'land storeman.
amazonian
« Reply #2 on: 10 April 2017, 21:08:16 »
But I understood that they were NOT the same at all?
So de ionized water is ok for coolant is it.
« Reply #4 on: 10 April 2017, 21:18:55 »
Our tap water is more than good enough for a coolant system ...... I put it in batteries too  :y
  • Online Online
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 10 April 2017, 21:22:12 »
Since Dad retired and lost the use of the school still, I've never had a problem using tap water. The water here is really hard, and quickly furs up kettles.
amazonian
« Reply #6 on: 10 April 2017, 21:31:04 »
I have never used anything but tap water for rads and batteries as well,  but then how little you know, how little I know!
  • Auckland
    • Mazda MPV
« Reply #7 on: 10 April 2017, 21:36:43 »
You are right - de-ionised water is not the same as distilled water. I wouldn't drink it or use it to make medicines but it is perfectly good for topping up batteries and cooling systems.
That said - I have never bothered to use anything but tap water in a cooling system.
biggriffin
« Reply #8 on: 10 April 2017, 21:38:12 »
With the amount of lectric fork lifts at your place, surprised you haven't got a 20L drum, for personal use. :-X
Hoof'land storeman.
« Reply #9 on: 10 April 2017, 21:53:38 »
But they are all on contract with Still   ;)
« Reply #10 on: 10 April 2017, 22:07:37 »
Yes, this is what I meant... ie not tap water, especially round here... Our water is so hard, it makes Moss Side look pleasant  :D
« Reply #11 on: 10 April 2017, 22:17:16 »
I always have. Never had any problems.
Haven't seen a battery that you could top up for years.
amazonian
« Reply #12 on: 10 April 2017, 22:21:08 »
ionized water it is then, thank goodness for that, at least I can buy that easily enough.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #13 on: 10 April 2017, 22:37:04 »
Using tap water was a problem back in the days of unsealed car batteries, where you had to top up regularly, especially if you had a poorly regulated dynamo which over-charged. Tap water with a high calcium content would then cause the plates of the battery to gain a limescale coating, reducing capacity and sfficiency.
Nowadays, topping up is almost unnecessary and calcification, IF it occurs, will take longer than the useable life of the battery to take place!
Pay for deionised or demineralised water if you must, but tap water is fine, really.....
Ron.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #14 on: 10 April 2017, 23:54:08 »
I use de ionized water to clean my R/C motors submerged
I run them for about 30 mins and all the carbon, dust and grit turn the water black
If I were to use tapwater it would short them out and blow the batteries
e46 325i se - 1.8vvti avensis liftback
Page created in 0.032 seconds with 20 queries.
