Author Topic: Strange code result..  (Read 3682 times)
neil74
  • newport
    • 2.6 elite estate.
« on: 11 April 2017, 18:32:08 »
Hello all.  Earlier I thought I would give the cheap code reader a blast only to find one of the codes it came up with is not on the list. the number is P0705 ? and of course the usual 0420/0430 ones that usually pop up all the time. is it an actual number or should the code reader be ignored.
Thanks
Neil.
Re: Strange code result..
« Reply #1 on: 11 April 2017, 19:18:05 »
Sounds like a gearbox one.  2 ticks....
« Reply #2 on: 11 April 2017, 19:20:34 »
P0705 - Range Sensor Circuit Malfunction
Or to you and me, clean the selector switch :y
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #3 on: 12 April 2017, 14:02:58 »
ditto, there is a generic description for this code: "Transmission Range Sensor Circuit (PRNDL Input)"
there's a generic list of codes here: www.uiftech.com/upfile/product/pdf/u380_manual.pdf
« Last Edit: 12 April 2017, 14:05:55 by migmog »
