Author Topic: MV6 -96 high idle when warm  (Read 3539 times)
kanaalinarvoitus
  • finland
    • MV6 -96
« on: 13 April 2017, 11:32:04 »
My omega is idling high when reached normal temp (about 1500rpm). I have cleaned ICV, chanced MAF, looked for airleaks. When disconnecting the ICV and plugging it back, idle lowers to normal for a 5 seconds, then back to 1500-2000. What to do? Could it be temperature sensor or what?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: MV6 -96 high idle when warm
« Reply #1 on: 13 April 2017, 14:21:59 »
What did you clean the ICV with?, Crab Cleaner?, something flammable?, is so, take the car for a good blast around and report back.
Failing that I would still be looking at air leaks.
kanaalinarvoitus
  • finland
    • MV6 -96
« Reply #2 on: 13 April 2017, 14:37:34 »
I cleaned it with crc oil, and compressor air. Although didn't look so bad in the first place. I could search air leaks with start pilot or something similar.
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« Reply #3 on: 13 April 2017, 16:29:49 »
I think this has another use.lol.Carb.
kanaalinarvoitus
  • finland
    • MV6 -96
« Reply #4 on: 13 April 2017, 16:42:41 »
https://www.dropbox.com/s/u2524qasbmubmbr/2017-04-13%2018.24.38.jpg?dl=0
Some progress! Found a tiny hole in this T-piece. Patched it up with tape ( ;D), then ran the engine hot. Idle was definetly lower (800-900rpm) for about 5 mins, then back high :-[. Does the ecu need to be reset or something? Where can i buy this T-piece, part number or link?
edit: Pic not working. Anyway the t-piece is the one closest to the hole where the oil is added.
« Last Edit: 13 April 2017, 16:52:55 by kanaalinarvoitus »
« Reply #5 on: 13 April 2017, 18:01:52 »
Do the throttle butterflies FULLY close?
kanaalinarvoitus
  • finland
    • MV6 -96
« Reply #6 on: 13 April 2017, 18:40:09 »
It was the tiny hole in t-piece (strange). I made a temporary fix from rubber hose and hose "clip", seems to work now. Idles perfectly at 600rpm. Thanks for help everyone!
moggy
  • hartlepool
« Reply #7 on: 13 April 2017, 19:43:05 »
Yes with crab cleaner.LoL.dEAN
zirk
  • Epping Forest
« Reply #8 on: 13 April 2017, 20:02:01 »
Carb Cleaner does have other uses.  ::)
You've not been sniffing it per chance have you Dean.  ;D
moggy
  • hartlepool
« Reply #9 on: 13 April 2017, 21:05:07 »
Yes it cheaper than crack. ;D
