How do breakdown men remove rusted on wheels?
Started by terry paget, 16 April 2017, 07:42:06
Quote from: RumpelStiltSkin on 17 April 2017, 09:42:17
Quote from: terry paget on 17 April 2017, 09:37:21
I doubt if tyre shops grease the hubs before fitting the wheels.
Or a torque wrench ;)
They often do, but don't seem to realise that their windy gun is set way way higher than the torque wrench  ???
I find steel wheels easy to fit on Omegas, but alloy wheels trickier 'cos I cannot easily see the threaded holes through the wheels, nor engage the screws in the threads with my fingers. I use a head torch and a 17mm box spanner.
What you need is a 100mm length of 12mm bar with a short length of M12x1.5 thread on one end. You hang the wheel off it, and replace it with the bolt having fitted the other four. Big Audis and some Peugeots have them in the toolkit.
PM me your address Terry, and I'll send you one.
terry paget
Quote from: Nick W on 17 April 2017, 12:13:31
Thanks Nick. PM sent
Webby the Bear
Dead blow hammer with one bolt wound in a couple of threads. Smash the living shit out of the back of the rim. Avoiding the tyre.
This method has never failed. Though I remember a BMW that put up some mighty resistance. All of those require dead blow persuasion.
RIP Paul Lovejoy
Dead blow. Is that what happened to your head?  ;D
Webby the Bear
Quote from: STEMO on 17 April 2017, 19:48:50
Yeah didn't take much  ;D
RIP Paul Lovejoy
Quote from: Webby the Bear on 17 April 2017, 19:46:13
There's a man who's never owned Irmscher wheel ;D
Quote from: RumpelStiltSkin on 18 April 2017, 16:07:03
Can't see a 19" BMW wheel being too chuffed about that either... ;D
Webby the Bear
Nah. DB hammer (which is rubber). Works on everything
RIP Paul Lovejoy
Quote from: Webby the Bear on 19 April 2017, 07:39:56
Trust me, it WOULD knacker most Irmscher wheels.  I buckled one (MFL MV6 standard one) just with a massive understeer moment.
A rubber mallet would distort most of them.
If I caught any garage using a mallet on any of my alloy wheels (esp the Irmscher ones), I'd be using the mallet on their head.
Webby the Bear
Quote from: RumpelStiltSkin on 19 April 2017, 09:35:30
What's different about these irmscher alloys in particular? By your description they sound completely unfit for the purpose of being an alloy wheel!
This isn't a "I know best" discussion. But I do this almost every day. Not one problem in the three years I've been there.
RIP Paul Lovejoy
Quote from: Webby the Bear on 19 April 2017, 20:30:41
Like anything Irmscher make, I would agree, they are barely fit for purpose.
And, honestly, without any shadow of a doubt, using a mallet on either a MFL MV6 wheel (not that there are any about nowadays, they were that bad) or an Irmscher Sportstar 18" would distort the rim. First hit.
Hence other methods needed for these (and, TBH, a lot of high end large alloys now) if the owner has been too lazy to maintain the car.  Also, hence, if I caught a garage doing it to TBE or the pussy cat (don't give 2 stuffs about battlebus, and the alloys look robust on that), I would be doing the same to the technicians' face ;D
Webby the Bear
Ok my bad I thought u were talking bout all cars' wheels.
So these irmscher ones. If u malleted if you'd see the distortion by eye? That's quite scary for owners of such things
RIP Paul Lovejoy
The 17" alloys fitted to Brabus Smart  Roadster's are the same ..... you can buckle them with a med/hard Paddington stare ;)
Quote from: Webby the Bear on 20 April 2017, 14:23:12
A lot of high end wheels are like that now. Obviously, not your run of the mill 10yr old Astra ones.
