Author Topic: lost t45 bolt help  (Read 9566 times)
slowboy
  • lode
lost t45 bolt help
« on: 19 April 2017, 15:05:58 »
doing cam cover gaskets on my mig 2.6.i have lost one of the six bolts which hold the injector bridge to the engine.tried stealer there all on the moon?any body got one they could post to me.will pay for post and bolt plus any commission.
Re: lost t45 bolt help
« Reply #1 on: 19 April 2017, 15:57:14 »
Which bolt - one that holds black sandwich plate to head, or manifold to black sandwich plate?
I can't do before weekend though, due to injury.  But that could be your fallback if nobody else comes up with anything
« Reply #2 on: 19 April 2017, 18:30:17 »
First question - where do you think you have you lost it? Need to make sure it hasn't dropped into your inlet ports especially, or any other areas such as into a suspension component etc. Of course, if you put all the bolts down on the bench, and then later lost one, it's not such a concern.
Assuming you're convinced it's not been dropped into the inlet ports - just use any old bolt of similar length (with the same thread) - readily available at B&Q, hardware stores etc.
Further tip - the "new" bolt with have a shallower, hexagonal head, so to make it easier to place it and tighten it, use it at the very front of the manifold, where it can be more easily seen and reached.
slowboy
  • lode
« Reply #3 on: 20 April 2017, 09:44:06 »
manifold to sandwich plate ,bolt dropped behind engine already had manifold in position.have used bolt from polski fiat handbrake as a stop gap but am worried the german made car may reject it. :D :D :D
« Reply #4 on: 20 April 2017, 12:35:44 »
Assuming I'm recovered enough by then, and assuming your location means Lode between Cambridge and Newmarket, I might be in Fordham next week ;)
slowboy
  • lode
« Reply #5 on: 21 April 2017, 15:13:06 »
Thanks for help problem solved garage down road had one to spare ;) :y
« Reply #6 on: 21 April 2017, 19:42:36 »
Working in my locality again?
« Reply #7 on: 22 April 2017, 09:11:47 »
Yeah  :'(
I have the scissors on standby to cut the skin that will grow between my digits.
Fraggles Rock
  • United Kingdom
« Reply #8 on: 22 April 2017, 09:46:19 »
Yeah  :'(
Wear gloves, you'll be fine ;)
« Reply #9 on: 22 April 2017, 10:35:04 »
Yeah  :'(
Give me a bell if you have any time... Curry perhaps?
« Reply #10 on: 22 April 2017, 10:52:27 »
Yeah  :'(
I'll see how things pan out :y
« Reply #11 on: 22 April 2017, 12:30:13 »
Yeah  :'(
:y Busy week for me too so it's going to be a last minute thing if we can :y
« Reply #12 on: 22 April 2017, 12:56:18 »
Yeah  :'(
Yup.  I suspect it'll depend on 2 key things...  ...how many evenings out with the team I'll have to endure, and how my knee holds up with the driving.
« Reply #13 on: 22 April 2017, 13:09:36 »
Yeah  :'(
1. I'm sure you'll cope  ;)
2. Want a man-up pill?  ::)
BTW, Cakey says you know that you're welcome here? Despite the pretty crappy time lately!
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #14 on: 22 April 2017, 15:40:44 »
Hopefully, a Tech 2 session is going to fit in there somewhere too.  :)
Page created in 0.035 seconds with 20 queries.
