Pages: [1] 2 3  All   Go Down
Author Topic: Best place to buy?  (Read 12054 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Best place to buy?
« on: 22 April 2017, 06:32:50 »
...Bilstein B4 (front) shocks? Also what springs should I go for?
I did consider looking into B6 but they'd probably be overkill, Plus paying a fair few more £££ compared to the B4, Yet no doubt the cornering ability would be much more responsive with the B6! But then again a new set of B4 should be more than good enough especially with the condition of the roads, Even the B4 should feel pretty solid compared to the worn out units they'll be replacing that are like a bouncy castle.
The current shocks from what I can tell (barely) the label/s have worn are seem to say Sachs/GM possibly the original and at over 200k...
    • 530D M Sport, 330i Coupe
Re: Best place to buy?
« Reply #1 on: 22 April 2017, 08:22:20 »
Balance Motorsport.
Eibach Springs get my thumbs up, MV6 LSC and Irmscher only available second hand.
« Reply #2 on: 22 April 2017, 10:46:50 »
Balance Motorsport.
And a full set will soon be available at my local scrapyard ;D
« Reply #3 on: 22 April 2017, 12:31:26 »
Balance Motorsport.
Not bothering to pull it off? Not much else of value really
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #5 on: 22 April 2017, 12:59:32 »
Balance Motorsport.
I've chrisgixer has already swapped over the front and rear suspension between the Bullet and TBE, in the hope that it will solve TBE's highly strung handling oddities.  If TBE can handle like the Bullet, I'll not be quite so sad to see the Bullet go  :'(
« Reply #6 on: 22 April 2017, 15:38:24 »
Balance Motorsport.
Oh, that explains the odd text I got. I think you broke him... He's gone very quiet about doing a swap between mine :-X ::)
« Reply #7 on: 22 April 2017, 17:39:23 »
Balance Motorsport.
Embarrassingly, I did have to leave him to do the rear on his own, as I was properly broken  :-[
Migv6 le Frog Fan
« Reply #8 on: 22 April 2017, 17:59:40 »
I think its time to change the forum name to OFF - Old Farts Forum.  ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #9 on: 22 April 2017, 18:06:02 »
Balance Motorsport.
These Eibach springs?
https://balancemotorsport.co.uk/eibach-pro-kit-springs-vauxhall-omega-b-25-26-27-03-94-07-03-front-axle-up-to-1080kg-e6532-140-1047.html
The only downside with these would be the 30mm lowering of the car, As it's already catching on the drive a little with the standard ride height.
Are there any stiffer springs that don't lower the car?
« Reply #11 on: 22 April 2017, 19:33:23 »
Balance Motorsport.
If you have standard suspension, what is catching?  That may imply you have another issue?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #12 on: 22 April 2017, 19:52:17 »
Balance Motorsport.
It's mainly due to the shape of the drive it's not a smooth gradual inclined driveway, There's a point where the center of longer cars such as the Omega say compared to a Corsa/Astra can occasionally just catch a little, On the Omega it's the exhaust mainly due to it being one of those 2 into one systems that doesn't fit like the original system... Anyway, Lowering the car isn't an option tbh.... It doesn't always catch as it is now but it's definitely going to be an issue if lowered 30mm.
« Last Edit: 22 April 2017, 19:54:30 by Mr.OmegaMan »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #13 on: 22 April 2017, 20:26:01 »
I replaced my 17 year-old 186,00mile stock Elite springs three months ago, and the front of the car came up nearly 30mm! These were £90 delivered for all four. It now rides properly, rather than just hammering into bumps.
It had new Sachs struts about 5 years ago, and stock air shocks on the back in 2015. Stiffer springs/shocks on an ordinary road going saloon are just unpleasant.
« Reply #14 on: 22 April 2017, 20:38:18 »
Balance Motorsport.
Plod springs...  Work with self levelling... Killen also do HD standard height springs... Linked to recently in this section :y
Pages: [1] 2 3  All   Go Up
Page created in 0.253 seconds with 20 queries.
