Author Topic: Front wheel bearing  (Read 7302 times)
Front wheel bearing
« on: 25 April 2017, 17:15:04 »
Whats the best source for a Front Wheel Bearing for a 3.2 please ??
Ominous speed related whine started today... goes quiet in right hand turns, louder in left hand turns, so suspect right hand wheel bearing.. but it is persisting down and I ain't getting wet just to check it out !!
Changed 70,000 miles ago ....
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Front wheel bearing
« Reply #1 on: 25 April 2017, 17:30:03 »
I fitted a Lucas one from ECP a couple of years ago Nige.
Seem to remember 65 quid rings a bell.
You will need some scaffolding and a long bar.
Watch out you don't smash the abs sensor when you abuse it off  ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 25 April 2017, 18:49:33 »
Try Keith abs, he might have one.
Hoof'land storeman.
« Reply #3 on: 25 April 2017, 20:37:05 »
Might be worth checking it's not just a sharp edge on a brake pad. :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #4 on: 25 April 2017, 21:48:05 »
Use Vetech (GSF) for pretty much everything due to low cost and lack of warranty claims* :y
*plus when asked what brand I always like to say "in vetech yo". The little things.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #5 on: 25 April 2017, 22:01:01 »
I haven't done my front wheel bearing(s) but once hub nut off wouldn't the old unit just slide off? Or are these known for seizing? Most bolt on bearing/hub complete assemblies on other motors just slide off the stub axle after hub nut off.
RIP Paul Lovejoy
« Reply #6 on: 25 April 2017, 22:17:17 »
You've got through some wheel bearings on that car  ......  ::) ;)
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #7 on: 25 April 2017, 22:22:55 »
I used Autovaux with no issues but I would think GSF or Euro Crap Parts would be similar in quality, I think I paid £35 a side.
Front hub nut is 200Nm and the the hub assembly just slides off  :y
« Reply #8 on: 25 April 2017, 22:29:15 »
I guess you could think that .. but the record shows one front one failed in France (Aug 2011, 108760 miles) and they "insisted" on changing both ... never felt or sounded right and MarkDTM diagnosed a badly made Front Nearside bearing at the "nearly wales" meet in September 2011 so it was changed (110006 miles).
Nearside rear bearing changed in April 2012 (114903 miles)
Now approaching 165000 miles so not to bad IMHO .. :)
« Reply #9 on: 25 April 2017, 22:30:57 »
Good thought .. hopefully, if its dry tomorrow, I'll find out .. :)
Webby the Bear
  • Northampton
« Reply #10 on: 25 April 2017, 22:33:50 »
The Makita would call that finger tight  8) ;D
RIP Paul Lovejoy
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 25 April 2017, 22:43:07 »
After some serious abuse from behind with a lump hammer  :-X ;D ;D
Webby the Bear
  • Northampton
« Reply #12 on: 25 April 2017, 22:45:00 »
 ;D
RIP Paul Lovejoy
« Reply #13 on: 25 April 2017, 23:42:02 »
Both of mine are still original at 206k. :-\
Keith ABS
  • Maldon Essex
« Reply #14 on: 26 April 2017, 07:27:22 »
I have one on the shelf Nige
Keith ABS
Page created in 0.026 seconds with 20 queries.
