Author Topic: Front wheel bearing  (Read 7320 times)
Re: Front wheel bearing
« Reply #15 on: 26 April 2017, 09:19:04 »
I fitted a Lucas one from ECP a couple of years ago Nige.
Seem to remember 65 quid rings a bell.
You will need some scaffolding and a long bar.
Watch out you don't smash the abs sensor when you abuse it off  ;)
I haven't done my front wheel bearing(s) but once hub nut off wouldn't the old unit just slide off? Or are these known for seizing? Most bolt on bearing/hub complete assemblies on other motors just slide off the stub axle after hub nut off.
I used Autovaux with no issues but I would think GSF or Euro Crap Parts would be similar in quality, I think I paid £35 a side.
Front hub nut is 200Nm and the the hub assembly just slides off  :y
320Nm
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #16 on: 26 April 2017, 10:49:48 »
320Nm
FT and a bit, in old money ;)
Hoof'land storeman.
« Reply #17 on: 26 April 2017, 15:17:52 »
Just got all the kit out to look at the problem and it bloody well started to SNOW !!!!!!!!!  All put away and the job will have to wait  ...  :)
« Reply #18 on: 27 April 2017, 16:46:35 »
28 degrees here if that helps :D
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #19 on: 30 April 2017, 11:19:04 »
After some serious abuse from behind with a lump hammer  :-X ;D ;D
You would have probably hit it with a hammer whether it needed it or not knowing you  :P ;D
Both of mine just pulled off with a small amount of force, no hammer required over here  ;D
Mr Gav
  • Leeds
« Reply #20 on: 30 April 2017, 11:21:37 »
320Nm
Ah yes...I forgot that my torque wrench only goes to 200Nm, IIRC I did it to 200Nm and then a further 90 degrees.
It was a good few years ago now  ;D
« Reply #21 on: 30 April 2017, 11:30:49 »
Big halfords one goes to 300nm which is pretty much enough :y
Mr Gav
  • Leeds
« Reply #22 on: 30 April 2017, 13:23:47 »
Yeah, I already had my Clarke torque wrench an I wasn`t buying another for two hub nuts  ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #23 on: 02 May 2017, 19:12:56 »
320nm. 7 dugga duggas  :y
RIP Paul Lovejoy
