Pages: 1 [2] 3  All   Go Down
Author Topic: Cam sensor  (Read 14559 times)
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #15 on: 27 April 2017, 20:56:18 »
Update: mechanic says low cam sensor pulse voltage and battery replacement. He said when car won't fire when he puts a booster pack on it the car fires straight away. Further tests tomorrow. Battery cranks forever with me and he's not saying the battery is going flat, just that his Snap-on tester says replace battery.
Re: Cam sensor
« Reply #16 on: 28 April 2017, 00:52:58 »
Battery testing best done as per Kevin Woods excellent guide :y
But replace cam sensor and report back... Failure is rare enough to take a punt on second hand genuine ones :y
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #17 on: 11 May 2017, 10:32:03 »
New genuine cam sensor fitted and battery ok, car sat on the drive for 3hrs then wouldn't start. I'm going to get an auto electrician to look at the car.
Re: Cam sensor
« Reply #18 on: 11 May 2017, 10:58:51 »
Follow Kevin Woods starting/charging guide...
Three hours with a door open WILL kill a less than brand new, fully charged battery...
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #19 on: 11 May 2017, 11:16:02 »
Just put a brand new Bosch S5 007 74Air battery on the car,  still won't start. After the cam sensor connection to the loom, does any know where the next connection is?
Re: Cam sensor
« Reply #20 on: 11 May 2017, 11:29:02 »
Does it turn over?
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #21 on: 11 May 2017, 11:34:27 »
Yes it turns over. It fired up for 10sec then cut out and wouldn't start again.
Re: Cam sensor
« Reply #22 on: 11 May 2017, 12:07:44 »
Check fuse 18 and if ok, do you hear the fuel pump run for a second or two when you turn the key to 2?
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #23 on: 11 May 2017, 12:26:14 »
I'll check it now
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #24 on: 11 May 2017, 12:35:01 »
Switch the ignition on a few times and I heard a click a few times, 3rd time I heard it run and cranked her and she fired.
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #25 on: 11 May 2017, 12:44:01 »
I checked fuse 18 and it is OK. If it is the fuel pump do I have to go for genuine part (delphi) or could I use a pattern part?
Re: Cam sensor
« Reply #26 on: 11 May 2017, 12:55:20 »
I checked fuse 18 and it is OK. It is the fuel pump do I have to go for genuine part (delphi) or could I use a pattern part?
Pattern is fine, although known good second hand will be plug and play... some pattern will require wiring mods (different connections). Upto you, but easy enough to change either way  :y
Not unusual for pumps to fail, particularly following cranking related faults ;)
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Cam sensor
« Reply #27 on: 11 May 2017, 13:00:32 »
is it saloon or estate? got a couple of known good pumps here from breakers
Re: Cam sensor
« Reply #28 on: 11 May 2017, 13:02:00 »
Pumps are all the same :y
phipps877
  • Bedfordshire
    • Omega 2.6 CDX
Re: Cam sensor
« Reply #29 on: 11 May 2017, 14:29:00 »
Mechanic is getting one in today at a cost of £85. Have I just paid for a cam sensor for now reason? And why did the code say cam sensor?
Pages: 1 [2] 3  All   Go Up
