Author Topic: Range 72 miles.  (Read 17334 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Range 72 miles.
« Reply #30 on: 02 May 2017, 19:48:22 »
I often get to the petrol station with 2 or 3 miles left. I have been to zero before which was a touch squeaky bum but didn't cough or anything. Which gives credence to the theory that there's still probably a good couple of litres (I guess) even after the dash says you're empty.
RIP Paul Lovejoy
New POD
  • Miseryside
    • NEED MV6
Re: Range 72 miles.
« Reply #31 on: 02 May 2017, 21:21:37 »
You are a brave man filling up at range 1 mile. My memories of Omega ownership include a strong one of always filling up every journey I made. A feeling akin to going to the gallows (I imagine ) came as soon as the red light came on.  :o
When I bought my Mv6 it's range was showing at 9 miles, and by the time, i'd test driven it and driven it to the petrol station, it was showing 0 (I think)
Re: Range 72 miles.
« Reply #32 on: 03 May 2017, 16:52:33 »
In the Jag, the book states:
Fuel capacity: 17g
Fuel capacity to empty: 15g
So to me, that's 2 gallons left at empty. But being lorry fuel, they are keen for you not to run out.
Interestingly, the petrol variant is:
Fuel capacity: 18g
Fuel capacity to empty: 17g
So real fuel has a bigger tank, plus it lets you run it dryer...
New POD
  • Miseryside
    • NEED MV6
Re: Range 72 miles.
« Reply #33 on: 30 January 2021, 08:48:08 »
Before lockdown, i was achieving 28 mpg, and since lockdown I've been achieving 15 mpg.
I should think about a more environmentally friendly car.
Before lockdown I was spending £70 a week on fuel and since lockdown, I've spent £170 on fuel.
Re: Range 72 miles.
« Reply #34 on: 30 January 2021, 09:57:44 »
I'm going to call Bullshit on that.
Re: Range 72 miles.
« Reply #35 on: 30 January 2021, 10:46:31 »
That's to say assuming that your mileage hasn't changed, you have doubled your pence per mile. (I assumed 300 miles for £X amount so 23ppm doubling to 56ppm).
If you were doing longer journeys and having to buy more fuel, your economy would improve, so your ppm would stay nearer 23ppm, and if you're using your car less, you wouldn't be using as much fuel. I think the worst I managed from an Omega was 220 miles from a tank. So even on that basis, you would only manage 38ppm and have travelled twice the mileage.
Basically £170 will fill it up twice ??? So either your leaving it idling all day or you have a significant leak.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Range 72 miles.
« Reply #36 on: 30 January 2021, 12:44:54 »
£170
Per week  :-\
OR in total because you're not using it much  :-\
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Range 72 miles.
« Reply #37 on: 30 January 2021, 13:13:49 »
Are you talking about the first alleged lock down in March, or all of the so called lock downs since? The one we're supposedly on now certainly doesn't seem like that around here.  ;D
Re: Range 72 miles.
« Reply #38 on: 30 January 2021, 13:21:19 »
I've just put 78 litres into The Barge to fill it.
I expect that to last until March ;D
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Re: Range 72 miles.
« Reply #39 on: 30 January 2021, 18:36:37 »
There’s a mathematical anomaly.... 23ppm. Doubled to 56ppm :y
Laying a rubber road.
Re: Range 72 miles.
« Reply #40 on: 30 January 2021, 22:27:55 »
Due to not having been near LPG, I put 90 litres of petrol in the 4.4 V8 Rangie earlier, at total cost £117.
19.7 Gallons in total. So at a (very generous) 15mpg, that will give me a range of 296 miles.
Oh well  ;D ;D :y
Re: Range 72 miles.
« Reply #41 on: 30 January 2021, 22:29:35 »
I put £99 into the ML last week .... (I paid at pump so that's all it would give me) .... it'll be lucky if it sees the next couple of weeks  ??? ;D
I've just been Top Trumped by James ...  ;D ;D ;D
Re: Range 72 miles.
« Reply #42 on: 30 January 2021, 22:38:15 »
I though £92 was bad enough :o
The Barge tank is 88 litres from memory, so it probably had another weeks worth in it, although the range wasn't too optimistic ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Range 72 miles.
« Reply #43 on: 30 January 2021, 23:05:18 »
Back when petrol was £1.35 a litre, I managed to get over £90 in my estate one evening.
    • Grandland 1.5 diesel
Re: Range 72 miles.
« Reply #44 on: 31 January 2021, 07:11:51 »
Oh well  ;D ;D :y
£12 gets me around 100 miles, and just as well the mileage I (normally) do.
Diesel till I die
Pages: 1 2 [3] 4  All   Go Up
