Author Topic: X20Xev cams out one tooth ?  (Read 2283 times)
Olympia5776
  • Ireland
« on: 30 April 2017, 15:48:02 »
When crank pulley notch is aligned with pointer, cam marks are as photo.
When cams are aligned with mark on head .
If I am correct is it a case of keeping the crank pulley mark aligned and then ,after removing old belt , gently reseting the cams to their alignment marks ?
Re: X20Xev cams out one tooth ?
« Reply #1 on: 30 April 2017, 16:41:03 »
I think as cams are advanced, I'd be locking cams in CORRECT position, remove belt, turn crank that tooth, then refit.
But see what a grown up says
Olympia5776
  • Ireland
« Reply #2 on: 30 April 2017, 19:10:14 »
Nope you were correct , took several attempts to get it spot on I even had to count the teeth on the belts (all 168 of them)to be certain  but all is well now .
New WP fitted too , tensioned and tested several times and all lining up as should be .
My back's giving me trouble so I'll fit the new thermostat and cam cover gaskets tomorrow and button it all  back up.
Checked and found I did the full cambelt kit and water pump in Aug 2013  .Car has done two thousand four hundred miles since  ::)
The problem was solely down to me. I always thought it had lost it's edge but put it down lack of use and being used to driving my E24.
Thanks for your help.
