Author Topic: OMEGA 2.2 New Engine (Engine Management Light ON)  (Read 2076 times)
windhoek_boy
  • Windhoek, Namibia
    • Omega 2.2 16V
« on: 01 May 2017, 18:50:03 »
Hi good people
My changed over my engine from my older Omega into a newer engine last year. Good enough the Engine Management Light was on but it eventually went off.
Engine eventually needed an overhaul after knock. And this was properly done by the usual Mechanic also on this forum. and it runs smooth. Problem is...this time after starting car for the very first time after engine overhaul 2 weeks ago,  the Engine Management Light or Engine Block light stayed on and does not go away. i have disconnected battery and reconnected it but this has  not gone away. What to do? does it need a resetting of some sort.
Re: OMEGA 2.2 New Engine (Engine Management Light ON)
« Reply #1 on: 02 May 2017, 16:21:38 »
You need an OBDII code reader to check what the problem is. Most engine problems will go dormant after a while and the light will go out, so the fact that it has stayed on suggests that there is a fault present. You need to check and rectify the fault and then the light will go out, or can be cleared with a code reader.
windhoek_boy
  • Windhoek, Namibia
    • Omega 2.2 16V
« Reply #2 on: 02 May 2017, 21:00:13 »
Alright. I will consult a guy i know with a reader.It must be something written MAXIDas i think.
Then i give feedback
