Author Topic: rear top mount diagram  (Read 1940 times)
laney101
  • liverpool
    • omega elite v6
« on: 09 May 2017, 16:54:12 »
does anyone have rear top mount diagram so as to check it all back together right as i know have a very slight knock after fitting new rear shocks. (genuine irmscher ones.) however dusct covers were shaped differently at top ..  so may also fit the original dust covers
Re: rear top mount diagram
« Reply #1 on: 09 May 2017, 17:50:35 »
You should have, top to bottom,
Nut
Washer
Rubber collar
Bodyshell
Rubber collar with neck pointing up
Washer
Shock.
There is also a metal bush inserted through the rubber collars. The shock rod runs through this and the nut clamps the bush, rubbers and mounting point between the two washers.
Either summat missing or you've used worn or shit replacement parts ;)
laney101
  • liverpool
    • omega elite v6
« Reply #2 on: 10 May 2017, 22:20:34 »
Cheers fella
