Author Topic: oil pan plug  (Read 2623 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
oil pan plug
« on: 10 May 2017, 14:00:19 »
  I think that I know the answer but just checking.  are all omega oil pan plugs the same ?? . my thoughts they are
Re: oil pan plug
« Reply #1 on: 10 May 2017, 14:14:52 »
Not in terms of the way the seal.
Later facelift ones use rubber O-ring, which have a very low Nm to tighten. Early versions use the copper washer.
But I think they are the same thread size.
Re: oil pan plug
« Reply #2 on: 10 May 2017, 18:54:24 »
There are variances based on engines and age.  I think most of the post 1998 GM engines use the same though...
ancient explorer
  • manchester
    • omega 2.2i. 2.5td. 2.6
Re: oil pan plug
« Reply #3 on: 11 May 2017, 03:36:03 »
Garage butchers stripped thread on my 2.5td on warranty service 17 years ago. Since then I put plumbers tape on the thread of bolt, and never had a leak or problem since! :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: oil pan plug
« Reply #4 on: 11 May 2017, 08:53:23 »
Haynes torque settings for torx head sump plugs are 10Nm, surprisingly low, but 45 or 55 for Hex head plugs. I imagine all torx plugs have O-rings and Hex plugs copper washers. Most Omegas I have owned had torx head plugs, but not all. The variety risks overtightening of the torx head plugs, especially by non-Vx dealers. It sounds like OP's car was damaged by a Vx dealer!
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: oil pan plug
« Reply #5 on: 11 May 2017, 11:12:13 »
I use one of these, Sealey 6.5L Manual Vacuum Oil and Fluid Extractor and on the Desmond I can change the oil filter from above.  ;) So I avoid the sump plug altogether. :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: oil pan plug
« Reply #6 on: 11 May 2017, 18:35:39 »
Snap, but I drilled & tapped mine out oversize. :y
Re: oil pan plug
« Reply #7 on: 11 May 2017, 18:37:15 »
Then mine was helicoiled. That finally solved it :y
