Author Topic: High mpg 2.2 petrol manual Z22XE  (Read 9089 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 16 May 2017, 19:40:15 »
Just unplugged the MAF sensor and took the car for a run. It ran the same with it unplugged as it did when plugged in. Does this mean the the MAF sensor is OK?
No fault codes are showing.
The car went through its MOT in March and passed its emissions test, while it was using a lot of fuel compared to usual.
What other sensors could cause the fuel economy to go up and how do I test them?
I have a holiday coming up in a couple of months, up north and want the fuel economy to be back to normal if possible.
flyer 0712
Re: High mpg 2.2 petrol manual Z22XE
« Reply #1 on: 16 May 2017, 20:03:04 »
I believe if it runs the same with it disconnected then the unit is ok.....have you cleaned out the throttle body and the breather hoses as these clog up with gunge and require regular cleaning.. :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 16 May 2017, 20:17:31 »
I take it you really mean Low mpg 2.2 as in Poor, rather than High, if so whats figures are we taking about.
Andy A
  • Bristol UK
« Reply #3 on: 16 May 2017, 20:34:54 »
That is what I thought.  :y
Yes just cleaned the throttle body and still poor fuel economy.
Andy A
  • Bristol UK
« Reply #4 on: 16 May 2017, 20:36:39 »
Yes its dropped to just under 16mpg local. Very poor compared to usual through the winter. :-(
« Last Edit: 16 May 2017, 20:38:54 by Andy A »
flyer 0712
« Reply #5 on: 16 May 2017, 20:45:37 »
Could it be fuel leak,,,,rusted steel fuel pipes that run under the car and maybe being porous and seeping through...Has it had a descent service recently,,plugs etc....silly thing but are tyre pressures correct ??..does it run at the correct temp and get up to temp as it should,,,,, :-\
Andy A
  • Bristol UK
« Reply #6 on: 16 May 2017, 20:50:09 »
Will check all tomorrow, rain permitting and time. Will let you know.
Thanks
Andy A
  • Bristol UK
« Reply #7 on: 17 May 2017, 12:28:03 »
Checked all of the above including tyre pressures and all is OK.  :y I did a full service around 2 months ago.  :y
Temp outside is 13 but the software I was using to check the codes said air temp was 20. Could this cause poor fuel economy?
« Reply #8 on: 17 May 2017, 14:02:47 »
No not really, what condition is the coil pack in?
Andy A
  • Bristol UK
« Reply #9 on: 17 May 2017, 15:08:11 »
Just looked and the coil pack looks in excellent condition.
« Reply #10 on: 17 May 2017, 18:55:15 »
What does the ecu think of the coolant temp? Ignore the gauge  :y
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #11 on: 18 May 2017, 19:38:26 »
Seems fine to me  :D :D
But then again i have a heavy right foot. Mine averages about 17-19 anyway  :y
Andy A
  • Bristol UK
« Reply #12 on: 19 May 2017, 07:16:28 »
Waiting for a replacement psu for the laptop to arrive. Will recheck when laptop is working again.
Andy A
  • Bristol UK
« Reply #13 on: 19 May 2017, 07:22:50 »
Mine has always been around 20 on avg but lately down to 16.
Andy A
  • Bristol UK
« Reply #14 on: 19 May 2017, 07:40:13 »
Unplugged the ERG this morning and took it for a short run. The pull of the engine below 3000 rpm was noticeably better. The car picked up speed a lot smoother and with a lot more go below 3000 rpm.
Will cleaning the ERG valve sort the mpg out or will it need replacing with new?
Can I reuse the gasket or is it recommended to replace with new?
I seem to remember that using a blanking plate to blank it off is a better option. What do you think?
