Modern car's features versus bad habits!
Started by Varche, 23 May 2017, 18:23:12
Migv6 le Frog Fan
Quote from: Andy B on 25 May 2017, 22:25:14
Quote from: Varche on 25 May 2017, 21:36:29
Grudgingly have to admit hill start assist on an auto worked well enough today. Mind you no manual handbrake!
We have just been having a discussion as to whether it is legal to use your left foot to brake? I have a sneaky feeling i am wrong and it is technically illegal but only if you caused an accident. Don,t try it tomorrow if you never have as you will find you have no control -just on or off!😕
I always left foot brake  :y :y
When I was invited to my speed awareness course  ::) a few years back, I was told off for doing so .... reason being,  I might press both pedals. I'm sure he could've thought up a better excuse.   ;D
So do I, in an auto.  :y
Quote from: Migv6 on 25 May 2017, 22:56:15
The first time I drove an auto was about 25 years ago when they had a brake pedal the size of an ironing board.
Instinct made me press my left foot to the floor while gently braking with my right foot the first time I stopped.............
Migv6 le Frog Fan
I had exactly the same experience.  ;D
BazaJT
I too have a tendency at times to left foot brake in an auto,although I find myself wondering why I do so,after all when driving a manual it's right foot for accelerator/brake and left foot for clutch so why does it feel "natural" to left foot brake in an auto?
Quote from: aaronjb on 25 May 2017, 17:05:36
Quote from: henryd on 25 May 2017, 16:07:55
I've been pleased with ours,very much dual purpose and happy towing pikey wagon or long motorway trips solo when it feels more like a big car than an offroader
Doing less miles I'd actually be inclined toward petrol next time (esp. if the gov't decides to murder diesel) - not much choice in petrol Touaregs or Q7s though! 2 of each for sale on Pistonheads and they're not as fast or capable as their diesel brethren..
Porsche Cayenne?
Quote from: Fuse 19 on 26 May 2017, 08:00:16
Porsche Cayenne?
Good point - same car essentially but with a better choice of engines that don't run on (as our esteemed Opti would say) the devils juice.
Still I'll probably be sensible and see out the finance on the Skoda ;D
When you're 90 years old and have ploughed through the front window of a chippy because you pressed both pedals, I guess he'll consider himself proven right... ;) ;D
Quote from: Andy B on 25 May 2017, 19:28:40
Quote from: Sir Tigger QC on 25 May 2017, 19:06:13
Quote from: TheBoy on 25 May 2017, 18:42:31
Quote from: Lincs Robert on 24 May 2017, 21:22:49
Keyless entry when combined with keyless ignition.  :y
For such a gimmicky thing, it soon becomes 2nd nature, and annoying when you jump in a car without it  :-[
The thing I've done with keyless entry cars, is when I park and walk away, but then because I have OCD or some other syndrome, I always have to go back and double check I've locked up.  ::)
And of course when I check the door it's open!  :D  ;)  ;D
How does keyless entry work if the place you keep your car keys at home is within range of the car?  :-\
It has to be very close ;)
Quote from: TheBoy on 26 May 2017, 18:53:58
Yeah. Close enough to put a fickin key in  ;D
Quote from: aaronjb on 26 May 2017, 09:33:53
when you're 90 years old and have ploughed through the front window of a chippy because you pressed both pedals, I guess he'll consider himself proven right... ;) ;D
If you press both pedals of most modern fly by wire throttles, you find that the throttle 'switches off' ..... besides, I'm  not sure I'll still be around in 35 yrs  :D
It wasn't very close on a Top Gear when they parked Capt Slow's car (a Ford?) in the middle of the street  :-\
Lincs Robert
Quote from: STEMO on 26 May 2017, 20:11:24
Yes - but without actually having to do it. Key stays in pocket, no need to touch anything  :y
Yes.  I believe the spec says the key has to be less that 1m from one of the detectors (door handles, or boot button) - I'll have a play later to see...   ...obviously, on mine and I guess all others, you can still use the remote in the traditional way, and it has a very good range on it (but then the fob is the size of a lorry)
Same with starting it. (ignoring silly "must press brake pedal to start" 'dangle berries'), you can't start unless somebody with a valid key is sat in the car. So can't start it stood by open drivers door.
Quote from: Doctor Gollum on 27 May 2017, 10:31:37
Even with the brake pedal pressed?
Yes. To start, the key has to be within a set distance of one of the internal receivers, in the same way it has to be within range of one of the external receivers to keyless unlock vehicle.
I tied unlocking, unsuccessfully, earlier today by hold key at arms length away from the car. So it does have to be quite close.
Mr Gav
Quote from: TheBoy on 27 May 2017, 18:43:42
My Z is the same, you have to be in very close proximity to the door handle, around half a metre but I`m sure the key works from the passenger seat once inside.
