Author Topic: Thermostat  (Read 2519 times)
laney101
  • liverpool
    • omega elite v6
Thermostat
« on: 24 May 2017, 15:56:11 »
Any one have trouble pushing thermostat down to locate into housing can't compress Courtney sport stat
Re: Thermostat
« Reply #1 on: 24 May 2017, 16:02:30 »
Nope, should sit nice and snug... But you'll be the first person to have bought one of those ::)
laney101
  • liverpool
    • omega elite v6
Re: Thermostat
« Reply #2 on: 24 May 2017, 18:50:02 »
Really first person .. sorted it anyways now cheers ...
Anyone know a lower fan switch so fans cut in sooner
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Thermostat
« Reply #3 on: 24 May 2017, 19:00:28 »
Very few people consider saving a couple of quid by buying just the thermostat(and not the housing) worthwhile.
Your local factors will have a book(or screen ;D ) listing the thread size and switching temperatures of their supplier's switches. You then pick one that will screw into your housing, and switches on(and off, which is probably the one to play with) when you want.
But seriously, what are you trying to achieve here? The stock Omega fans switch in and out seamlessly at about 100C, which seems pretty good to me. If yours are doing that, but the car is overheating(and that means venting coolant) then you should fix the cause, not fudge it with a fan that runs more often.
Stige
  • Finland
    • -68 Satellite, -97 MV6
Re: Thermostat
« Reply #4 on: 24 May 2017, 19:05:24 »
Well optimal temp for performance is like 70C I think, so there is that?
  • Chatham, Kent
Re: Thermostat
« Reply #5 on: 24 May 2017, 19:10:31 »
I think that increased back when they started fitting water pumps to engines ;)
laney101
  • liverpool
    • omega elite v6
Re: Thermostat
« Reply #6 on: 25 May 2017, 22:54:48 »
I fitted new Courtney lower temp thermostat and a new first line housing along with new genuine link pipe
Car is fine now thankyou new thermostat and hbv and all good no coolant loss and running a lot better...
U answered own question in asking whŷ fit lower fan switch when fans kick in at 100degrees.. should never let it get that hot... oil needs to be 80 degrees to function properly but having engine at 100degrees not good so having fans kick in low 90s be more beneficial to engine to keep operating temperatures at sweet point low 80s to 90s temp range
 keeping engine in better condition ... obviously too low and nothing is running at optimum but few degrees lower for fans be a lot better
Think I found one of a Renault... just the pins for fans are opposite so c1 and c2  pins other way around so opposite fans kick in first to std
« Last Edit: 25 May 2017, 22:57:48 by laney101 »
