Author Topic: Engine numbers  (Read 4420 times)
Superleggo
  • Liskeard
    • Passat
Engine numbers
« on: 24 May 2017, 23:31:11 »
Hi
I am building a special and I am using an engine and box from an Omega. I think my engine is a 3.0 and manual gearbox but not sure as the engine number and log book(V5) do not seem to match.
The logbook shows engine no 08254289 which I guess is 2.5 ltr
But the engine is difficult to read but looks like G4 150A 78777 which I think is a 3.0ltr
Is this correct? What sort of power does it make the seller told me 210hp?
korum
  • Derby
    • 2003 3.2 Irmscher MV6
Re: Engine numbers
« Reply #1 on: 25 May 2017, 07:40:48 »
Can you see the block of the engine as it should have the engine code stamped on it IE x30xe or x25xe
The 3.0 does make around 210bhp
Superleggo
  • Liskeard
    • Passat
Re: Engine numbers
« Reply #2 on: 25 May 2017, 23:26:42 »
Yes I can see the engine very easily as it is in a rolling chassis with no body work around it. It is clean and the numbers posted are the only numbers I can see they are one the LHS in the flange by the oil filter near the gearbox. Are there other numbers I should be able to find?
annihilator
  • Wirral
    • Omega Tourer V6
Re: Engine numbers
« Reply #3 on: 26 May 2017, 19:22:10 »
that sounds the right location to me,this is what one I currently have in bits in my back yard says on it
Is the oil filter a spin on or cartridge type?
John  :y
« Last Edit: 26 May 2017, 19:27:10 by annihilator »
Re: Engine numbers
« Reply #4 on: 26 May 2017, 19:49:47 »
Might have been a replacement new engine :-\
Superleggo
  • Liskeard
    • Passat
Re: Engine numbers
« Reply #5 on: 26 May 2017, 23:09:32 »
I am sure the engine is a replacement.
The oil filter is cartridge type.
I will try and photograph the engine not this weekend
  • Auckland
    • Mazda MPV
Re: Engine numbers
« Reply #6 on: 26 May 2017, 23:27:35 »
John  :y
Where exactly is that number? Have you got another photo taken from slightly further away?
I have never managed to find the number on any of mine :-\
Superleggo
  • Liskeard
    • Passat
Re: Engine numbers
« Reply #7 on: 27 May 2017, 10:11:48 »
The engine number reads
G4 150 A 78777
annihilator
  • Wirral
    • Omega Tourer V6
Re: Engine numbers
« Reply #8 on: 27 May 2017, 11:34:15 »
don't recognise those numbers another way to check is the ident. on the camshafts
x30xe exhaust A type inlet G type
x25xe exhaust E type inlet F type
John.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Engine numbers
« Reply #9 on: 28 May 2017, 22:57:22 »
« Last Edit: 28 May 2017, 22:58:57 by ffcgary1 »
Jaguar XJ6
Superleggo
  • Liskeard
    • Passat
Re: Engine numbers
« Reply #10 on: 31 May 2017, 22:29:08 »
looks like I have beaten you guys on this engine number!
korum
  • Derby
Re: Engine numbers
« Reply #11 on: 01 June 2017, 17:24:45 »
Right remembered today to get a couple of pics at work.
HTH
andyc
  • Norfolk
Re: Engine numbers
« Reply #12 on: 04 June 2017, 23:09:16 »
G4 150 A 78777
That is not a Vauxhall /GM Engine Number. That engine has been re-conditioned and that would be the number the re-conditioner would use
Thetford. Norfolk
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Engine numbers
« Reply #13 on: 05 June 2017, 09:58:18 »
Picture of plenums might help.  Short its a 25 long its a 30
Hoof'land storeman.
