Author Topic: Air con not kicking in  (Read 1772 times)
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« on: 31 May 2017, 07:53:58 »
Hi, i was testing air con pump and it isn't kicking in. Tried low temp and eco off, plus most of other settings and no dice. When I say not kicking in, I mean compressor is not engaging. I gave the Schroeder valve a little tip with a screwdriver and seems plenty of gas pressure coming out. Also seems on temp low the air is at best warmish not cold. That was after leaving it for a while to cool.
« Last Edit: 31 May 2017, 08:00:47 by grifter »
omega2018
    • MercCL500 Omega2.6ManElit
Re: Air con not kicking in
« Reply #1 on: 31 May 2017, 17:03:33 »
sounds like a re-charge is due.  not sure about your method of testing the pressure - it may be illegal and anyway can you tell >30-70 psi like that?
grifter
  • Paisley, Scotland
« Reply #2 on: 31 May 2017, 20:21:23 »
Well i suppose guilty as charged! No idea pressure, so will swing by halfords and get them to check it.
