Author Topic: Door strap "cracking" not fixed with new bush  (Read 16957 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Door strap "cracking" not fixed with new bush
« Reply #15 on: 04 June 2017, 13:34:40 »
Ok thanks Andy. So instead of that whole panel I simply need this bodge kit from Vauxhall
RIP Paul Lovejoy
« Reply #16 on: 04 June 2017, 13:49:04 »
Yes. But they're easy to make yourself from a bit of scrap plate.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #17 on: 04 June 2017, 16:06:37 »
Do you have the dimensions of the plate so I can try and make some and do you have the size and length for the replacement bolts needed?
« Last Edit: 04 June 2017, 16:08:31 by Andy A »
Webby the Bear
  • Northampton
« Reply #18 on: 04 June 2017, 16:41:25 »
Yeah I'm sure I've got some scrap too if anyone has the dimensions.
If I've got this correct then the holes in the plate will be tapped ready to accept the bolts?
RIP Paul Lovejoy
« Reply #19 on: 04 June 2017, 17:05:26 »
Nope... the bolts go into captive nuts on the check strap assembly.
Kit contains longer bolts because the reinforcement plates are 3/8" or so thick... times two and that makes a lot more than sheet steel for the original bolts. ;) ;)
Webby the Bear
  • Northampton
« Reply #20 on: 04 June 2017, 17:10:44 »
Right thanks DG. Having looked at a check strap online (never even seen one off the car before) you have the plate that's part of the check strap with captive nuts.
You then fit a repair plate in front of that.
Then refit to car and the check strap with bodge plate fits up against the metal plate which is part of the door.
Then another plate in front of that.
Is that right?
RIP Paul Lovejoy
« Reply #21 on: 04 June 2017, 17:16:33 »
Yep. Door shell sandwiched between the two reinforcement plates, bolts through from the outside and check strap assembly inside...
Webby the Bear
  • Northampton
« Reply #22 on: 04 June 2017, 17:19:02 »
Ok now I got it. Thanks all for the replies  :y :y :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #23 on: 04 June 2017, 17:21:26 »
Are the reinforcements plates roughly 5mm thick each? If so I'll make some as I'm sure we've got some thicker metal knocking around  :y
And some shaved down cam cap bolts  as I have shite loads of them  :y assuming they're same thread of course
RIP Paul Lovejoy
steve6367
« Reply #24 on: 04 June 2017, 17:23:05 »
If it make any difference to your thought process the kits is readily available form VX and cheap.
Webby the Bear
  • Northampton
« Reply #25 on: 04 June 2017, 17:24:59 »
Yeah was just reading the thread. For the sake of five notes I'll get them from Vauxhall  :y
Cheers everyone  :y
RIP Paul Lovejoy
« Reply #26 on: 04 June 2017, 18:10:35 »
How thick?  ::)
« Reply #27 on: 04 June 2017, 18:21:36 »
Mince thick...
Webby the Bear
  • Northampton
« Reply #28 on: 05 June 2017, 23:17:01 »
Big praise to OOF. Called dick heads at Vauxhall today. They were adamant this repair kit was unavailable...... til I have them part numbers from the guide Andy posted.
Now got repair kit en route for 6 pound summat inc. vat.
Cheers oof. Legends!!!
RIP Paul Lovejoy
« Reply #29 on: 06 June 2017, 11:44:03 »
 :y :y
Pages: 1 [2] 3 4  All   Go Up
