Author Topic: yellow spark plug  (Read 9758 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: yellow spark plug
« Reply #15 on: 09 June 2017, 00:26:05 »
I don't lubricate plugs but I would put a drop of oil on the threads if I thought there was going to be an issue getting them out.
whoever fitted the plugs on this week's Yak 18t didn't use copperslip. 3 of them loosened properly; the other 15 needed a long ratchet, fluent anglo-saxon and some prayer. I never fit plugs without lubricant.
« Reply #16 on: 09 June 2017, 15:09:13 »
On the old tapered seat plugs I would agree (ala the horrific abortion that was the Ford pushrod where the plugs were mounted at the front in the wet and spray with a tapered plug seat) then yes I would agree.
The modern plug its not an issue IF its fitted correctly  :y
« Reply #17 on: 09 June 2017, 15:25:25 »
Correct response is, of course, to "take it for an Italian tune-up" to see if the heat loosens them.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #18 on: 09 June 2017, 17:46:01 »
forgot to mention,  engine oil contains copper molecules....
« Reply #19 on: 09 June 2017, 18:18:11 »
You've made your point >:(
