Pages: 1 2 [3]  All   Go Down
Author Topic: Best way to join wires - car electronics  (Read 16939 times)
Re: Best way to join wires - car electronics
« Reply #30 on: 12 June 2017, 23:46:08 »
If you look at practically any connector on any car loom, 99 times out of 100 it'll be crimped at the factory.
When the wire, connector and tool are 100% compatible, it is a very reliable method of connection in an environment with movement and vibration like a car, because it doesn't concentrate stress on the cable like a soldered joint does.
However, DIY crimping tools are not great unless you spend quite a bit, and you need exactly the right size connector for the wire, and the right tool for the connector. I must admit, if I need to connect something to a car loom I generally use a solder joint, but I make sure it's supported by heat shrink sleeving and, preferably, cable tied to something solid locally to stop the wire flexing.
Don't use a scotchlok, whatever you do. ::)
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #31 on: 13 June 2017, 00:10:18 »
No fear! When I first got my kit car (more than a decade ago), I spent an unpleasant 3 weeks one summer removing about 100 scotch locks and trying to decipher the loom. The sadistic b@stard who built the damn thing only used light blue wires - and I mean for EVERYTHING!  >:(
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #32 on: 13 June 2017, 00:36:07 »
I usually take the car to work and get a professional to do it. I struggle to solder with two hands, Christ knows how Webby would even attempt it.  ::)
Scalding hot solder gun held under my "small arm" 😂 Twisted wires sat carefully on top of iron. When all wires hot enough solder flows through. But it's a right ball ache if they are thick wires as takes ages to heat. These heat shrink connectors are done in a couple of minutes even by me 😂
You must be very determined mate. I would like to try to replicate this, just to see how difficult it is, but I know I would burn holes in myself from head to toe.  ::) ;D
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #33 on: 13 June 2017, 08:04:11 »
Rewiring MrsGKs Polo,half the wires for the banging sound system were Scotchlocked, half of them twisted together and taped... Several of them burnt!
« Reply #34 on: 13 June 2017, 09:26:59 »
Yes, indeed. I take my hat off to you, Webby. :y Since "electron herding" is my hobby, I do quite a lot of soldering and normally two hands aren't quite enough.
I find a "helping hands" very useful in this scenario.
http://www.clasohlson.com/uk/Helping-Hand-Work-Aid/30-7666?gclid=CJrjoeuyutQCFUQz0wod-YEKnA
You can use it to hold the wire and connector in place, then you can apply the solder and iron.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #35 on: 13 June 2017, 10:52:03 »
An excellent tool, i have had mine for years, and cannot imagine how I managed to solder before I had it.
Viral_Jim
  • Telford
« Reply #36 on: 13 June 2017, 10:57:53 »
I went for 2 stacks of magazines, with one wire sandwiched in the middle of each stack. That said, if I had to do more than half a dozen wires every decade or so, I might have to invest in an alternative solution!  ;D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #37 on: 13 June 2017, 12:42:16 »
Bloody hell! I've got one of those...wondered what it was  for ::)
I like red cars
  • Online Online
« Reply #38 on: 13 June 2017, 12:49:33 »
;D ;D ;D ;D ;D ;D
TD
  • Swindon
    • Nowt!
« Reply #39 on: 13 June 2017, 18:01:19 »
In my yoof I used to work for a company that manu'd 16/18in 10/12 copper layer circuit boards.
All the components were surface mounted.....
When they didn't work I had to fault find them and change the duff component.....
This involved peering through a dual microscope just to see what you were doing and the soldering iron tip was heated with RF energy as it so fine...IIRC the soldering irons cost about £500 each and the tips for the irons about £50 each.....which would need replacing every week as the irons were left on 8/10hrs a day........
Probably what buggared up my eyesight...... :-\
Migv6 le Frog Fan
  • Online Online
« Reply #40 on: 13 June 2017, 19:05:07 »
;D ;D ;D ;D ;D ;D
I see them all over the place on work and had no idea what they were for either.  ::)
« Reply #41 on: 13 June 2017, 19:13:17 »
Handy bits of kit, not that I've replaced mine following the garage incident.  I should really.  And its my burfday soon.
Pages: 1 2 [3]  All   Go Up
