Author Topic: Number plate  (Read 2772 times)
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Number plate
« on: 11 June 2017, 02:17:27 »
Hi does anyone Know what the part number the rear number plate plastic screw retainer with the metal clip on the back part number is. or a replacement part number, as replaced rear number plate and they were rusted as not sealing, and took cover off and both are broken. thanks
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Number plate
« Reply #1 on: 11 June 2017, 07:24:56 »
Bin the screws and stick the number plate on with trim-tape.
tidla
  • solihull
Re: Number plate
« Reply #2 on: 11 June 2017, 11:52:56 »
Looks much better and an idea opportunity to bin the European logo stuck on the end of the plate if you have one. ::)
Chazza12
  • south yorkshire
Re: Number plate
« Reply #3 on: 11 June 2017, 18:23:40 »
the replacement plates come with gb and euro log on them, but you can get a british flag to cover the euro if you want. i had drilled the holes from old plate before noticing the rust. found something to do it anyway. used them tube fixing plugs for long screws melted both ends flat and cut it in half and fitted nice and tight and sealed. so number plate on now :)
Re: Number plate
« Reply #4 on: 11 June 2017, 18:40:40 »
the replacement plates come with gb and euro log on them,  ....
Depends where you get them from ..... Euro stars are not obligatory  :y
Chazza12
  • south yorkshire
Re: Number plate
« Reply #5 on: 11 June 2017, 21:43:55 »
I tried getting normal type but they all came with the blue part, that has them on. they even security marked. dont know what it means, my originals were original vauxhall garage that is no more.
Re: Number plate
« Reply #6 on: 11 June 2017, 22:16:43 »
I tried getting normal type but they all came with the blue part, .....
Plenty online that give you the option  :y
E.g. https://www.fancyplates.com
Chazza12
  • south yorkshire
Re: Number plate
« Reply #7 on: 11 June 2017, 22:36:10 »
Cost Of Plates
£20.00
just for standard just 1. pre 2001 type. ????
