Author Topic: Check engine light  (Read 4043 times)
chrisr
    • 02 2.2 petrol
Check engine light
« on: 11 June 2017, 12:12:36 »
On a fast, fully loaded trip back from North Devon to Surrey yesterday my check engine light came on while accelerating away from a set of lights. The car ran and still seems to be running normally. I disconnected the battery to try and clear the light but no luck. The pedal trick did not work. Any ideas? 2.2 2002 petrol auto.
Thanks.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Check engine light
« Reply #1 on: 11 June 2017, 14:52:41 »
Does it go out after a restart?, after a few hours that is. Mine was a cam sensor. If you do need one, buy only from a main GM dealer and get it yourself. :y
chrisr
    • 02 2.2 petrol
« Reply #2 on: 11 June 2017, 18:25:28 »
No, still on today after a few starts and a run out, car still seems to run fine though.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 11 June 2017, 22:48:40 »
I had that on my 2.6 V6; a dose of Cataclean, a tank of Shell V-Power and an Italian tune-up clered it! I did get a code, though, telling me that the N/S cat efficiency was low.
Ron.
« Reply #4 on: 12 June 2017, 09:46:32 »
You need to get the codes read, before taking any action.
« Reply #5 on: 12 June 2017, 10:34:23 »
Yep, no point guessing. It could be anything at this stage. Get it to an OBDII code reader and see what it's reporting.
« Reply #6 on: 12 June 2017, 11:13:27 »
Where in Surrey are you?
« Reply #7 on: 12 June 2017, 11:43:21 »
Desmond cam sensor can cause this as well... Cross checked with a code reader and lots of random gearbox codes ;)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #8 on: 12 June 2017, 12:19:40 »
If it is the cam sensor I have a known good used GM one off my breaker
chrisr
    • 02 2.2 petrol
« Reply #9 on: 12 June 2017, 13:29:30 »
I'm in Surbiton, but am happy to travel to anyone with a reader
chrisr
    • 02 2.2 petrol
« Reply #10 on: 12 June 2017, 13:37:19 »
Thanks, I'll be in touch when I find out what the problem is
« Reply #11 on: 12 June 2017, 18:22:22 »
*IF* it is a cam sensor - and don't randomly change parts until it is proven via a code reader - don't bother with pattern or 2nd hand. Go to a dealer, and buy a real one from a real dealer.
