Author Topic: Smokey headlights.  (Read 3988 times)
REvil71
  • Wales
    • 3.2 Elite Saloon
Smokey headlights.
« on: 12 June 2017, 13:44:56 »
Hi.
Chatting to a car guy the other day and he said toothpaste is excellent in cleaning and clearing foggy headlamps.
Don't know if it works but thought I would put it on here just incase it helps anyone.
Luckily mine are all clear.
peter the butcher
  • knaresborough, north yorkshire
  • omega driver as a hobby and now retired :-(
    • 2.6CDX
Re: Smokey headlights.
« Reply #1 on: 12 June 2017, 14:43:21 »
toothpaste is ok, IF you just catch them in time I suppose, I have tried it. But I think the ONLY way of doing it properly, is to follow the guide on here, or if you have oodles of money, and just get lens replaced lol  ;D
« Reply #2 on: 12 June 2017, 18:25:14 »
Generally needs something must harsher.
    • 530D M Sport, 330i Coupe
« Reply #3 on: 12 June 2017, 18:28:36 »
G3 works quite well with a suitable polisher, I need to replace either the whole headlight or the lense on one of mine as it appears to be yellow on the inside.  >:(
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 12 June 2017, 18:39:20 »
This.
Toothpaste is a very fine abrasive, and will struggle to remove the grot on a headlight.
The key to doing this job efficiently is to use wet&dry(1000grit is usually enough) to start with, and restore the finish with a decent compound - G3 in my case. It's a small enough area that doing it by hand isn't a problem. This procedure takes me about 10minutes per lamp, without taking them off the car.
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« Reply #5 on: 12 June 2017, 18:41:05 »
Wet and dry and then a plastic polish. Meigars rings a bell. :y
Magwheels
    • 2.2 dti Elite saloon
« Reply #6 on: 12 June 2017, 20:40:00 »
This.
I the just clear coat them. They then stay nice and clear.  :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #7 on: 15 June 2017, 09:10:24 »
Did mine with brasso yesterday. Works quite well for me.  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 15 June 2017, 10:01:30 »
I got a Quixx kit as mentioned before. However the kit contains wet n dry and a bottle of quixx branded t cut lol
RIP Paul Lovejoy
