Pages: [1] 2 3  All   Go Down
Author Topic: Demist winter  (Read 13781 times)
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
Demist winter
« on: 13 June 2017, 01:26:43 »
Observing some of the comments on this forum, mine mists up terribly in the winter. If the climate isn't working, as it is not one mine, for demist. Is this a common problem with the Omega?
Re: Demist winter
« Reply #1 on: 13 June 2017, 01:39:53 »
If by climate not working, you mean the aircon... then yes, it will mist up terribly.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Demist winter
« Reply #2 on: 13 June 2017, 12:49:16 »
Keeping the windscreen impeccably clean on the inside will help.
omega2018
    • MercCL500 Omega2.6ManElit
Re: Demist winter
« Reply #3 on: 14 June 2017, 03:25:02 »
check the vents in the boot are clear - drivers side bottom of first aid box cubby hole
wipe the screen with a mild detergent solution or buy the same thing - anti mist screen wipes.
fix your air con
atann
  • Canterbury
Re: Demist winter
« Reply #4 on: 14 June 2017, 21:19:08 »
fix your air con
Thanks, never checked that. Will update.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Demist winter
« Reply #5 on: 15 June 2017, 18:45:31 »
spoke today to an aircon specialist. they told me that not having working aircon shouldnt cause any issues and the car demist should behave just like any ordinary car that doesnt have aircon.is ther any peculiarities in the omega system that causes the misting up ? just curious
Re: Demist winter
« Reply #6 on: 15 June 2017, 19:07:05 »
Yup, shit, lazy design... ie poor air distribution which relies heavily on working airconditioning to function acceptably ;)
  • Auckland
    • Mazda MPV
Re: Demist winter
« Reply #7 on: 15 June 2017, 20:17:06 »
Occasionally the recirculation flap on my car will get confused and stick in the recirc position.
When that happens the screen mists up in moments.  >:(
zirk
  • Epping Forest
Re: Demist winter
« Reply #8 on: 15 June 2017, 21:20:14 »
A wet / damp Pollen Filter doesn't help.
Re: Demist winter
« Reply #9 on: 15 June 2017, 21:37:23 »
Good point well presented ;)
cam.in.head
  • West yorkshire
Re: Demist winter
« Reply #10 on: 15 June 2017, 22:06:02 »
when i first got mine it was hard to demist but refitting the lower plastic arms that had come off and a couple of matrix flushes got it working fine.never had a car with aircon so never too bothered about getting mine working.all been fine since
atann
  • Canterbury
Re: Demist winter
« Reply #11 on: 15 June 2017, 23:07:14 »
How do you check that? Where is it located?
Re: Demist winter
« Reply #12 on: 15 June 2017, 23:17:18 »
Passenger side scuttle :y
zirk
  • Epping Forest
Re: Demist winter
« Reply #13 on: 15 June 2017, 23:19:50 »
2 min job, lift bonnet, NS on the scuttle panel, lift flap, pull out Pollen Filter.
Stige
  • Finland
    • -68 Satellite, -97 MV6
Re: Demist winter
« Reply #14 on: 16 June 2017, 06:51:07 »
90% of the time its the pollen filter that does this.
Pages: [1] 2 3  All   Go Up
