Author Topic: Exhaust join help  (Read 4484 times)
Exhaust join help
« on: 21 June 2017, 16:49:47 »
The Imrscher backbox on TBE is the usual Irmscher twin outlet affair, one outlet each side.  The O/S pipe attaches to the pipe coming out of the backbox silencer, just behind the tank, using a metal ring, and an exhaust clamp that clamps both halves of the exhaust to this ring.
What is the ring called, as TBE's is probably somewhere along the M40 :(
TIA
Re: Exhaust join help
« Reply #2 on: 21 June 2017, 17:41:51 »
« Reply #3 on: 21 June 2017, 17:46:07 »
Hope this explains what pug ones are like...
« Reply #4 on: 21 June 2017, 17:46:27 »
I need that taper on both edges :y
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Chazza12
  • south yorkshire
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 21 June 2017, 17:53:26 »
Your local motor factors will have them; I've bought them as both exhaust sealing rings and exhaust olives. You buy them by size, and they take on the concave shape when you tighten the clamps.
« Reply #8 on: 21 June 2017, 17:55:46 »
Sure my 106 one was tapered both sides :-\
The irmsher one is a solid lump, which rots from the outside in...
Think the fracas has one as well :-\
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 21 June 2017, 18:31:18 »
I'd call that a graphite doughnut gasket. And ask for one that's tapered both sides
RIP Paul Lovejoy
« Reply #11 on: 22 June 2017, 08:37:31 »
Should be easy to get, they were standard fit on Astra G/Zaf A (and yes they were tapered on both sides) described as a conical exhaust seal
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #12 on: 22 June 2017, 15:30:04 »
astra g and honda are single side taper at the flange,
it looks similar to my volvo 850, a band clamp holding a ball and cup together
e46 325i se - 1.8vvti avensis liftback
« Reply #13 on: 22 June 2017, 18:11:56 »
The conical one I bought was only tapered one side, hence this thread :)
