Author Topic: Hot  (Read 7320 times)
Re: Hot
« Reply #15 on: 24 June 2017, 11:35:55 »
Potentially, depends on the specifics of the car in question...
Well its a 2004 1.6 Octavia if you have any idea, I could pm you and pick your brain a little?
Sorry, but not a car I would touch with yours...
Only things that spring to mind are:
Cap failed
Waterpump leak/weak having not been changed with cambelt
Heater matrix blocked/chemical sealant/sludge in system
All pretty standard coolant culprits, but couldn't tell you how susceptible that engine would be :-\
Stige
  • Finland
    • -68 Satellite, -97 MV6
Re: Hot
« Reply #16 on: 24 June 2017, 13:09:03 »
Cap failed
New pump+timing stuff, new thermostat and still no flow to radiator really, bottom hose is cold... When upto temps, get hissing noise from the reservoir as pressure is escaping and little coolant loss too.
Re: Hot
« Reply #17 on: 24 June 2017, 13:55:48 »
Rad knackered then...
omega2018
    • MercCL500 Omega2.6ManElit
Re: Hot
« Reply #18 on: 25 June 2017, 01:05:38 »
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
Re: Hot
« Reply #19 on: 13 July 2017, 10:11:29 »
Put a litre of coolant in tank on Tuesday morning. Coolant level light came on this morning during daily commute to London, 90 mile round trip on M1/A406/A40. Temp 90-94. Fans OK. Can smell it after daily run. Loosing it somewhere but not sure where.
Serek will take a look for me next week.   :(
Re: Hot
« Reply #20 on: 13 July 2017, 10:14:37 »
Probably the HBV  :y
Lagondanet
  • Bedfordshire
    • Lagondanet
Re: Hot
« Reply #21 on: 21 July 2017, 07:14:46 »
HBV. Replaced by Serek.  :y
« Last Edit: 21 July 2017, 07:16:46 by Lagondanet »
Page created in 0.026 seconds with 16 queries.
