Author Topic: Calliper Hole Spacing.  (Read 3424 times)
Davey
  • Berkshire
« on: 03 August 2006, 08:54:08 »
I was looking round a friend of the families lockup last night and came across a brand new set of Mercedes 4 pots and 330mm discs, the PCD for the merc is almost the same as the omega (5x112), just wondering if anyone knows the bolt hole spacing on the calliper mounting brackets i.e. the distance between the centre of the two holes, I don't have an omega calliper to hand so can not compare. However the merc item has 100mm spacing.
Cheers!
Re: Calliper Hole Spacing.
« Reply #1 on: 03 August 2006, 09:04:15 »
I dont know the spacing but, there is a reasonable chance they will fit as Mercedes use the same brake setup supplier....
Davey
  • Berkshire
« Reply #2 on: 03 August 2006, 09:08:25 »
Bonus!
I need some decent anchors for the new engine and these seem to be a promising solution, plus they'll look standard in the black powder coat ;)
