Author Topic: Scoobie Legacy cut out issue  (Read 21556 times)
Re: Scoobie Legacy cut out issue
« Reply #15 on: 23 June 2017, 13:32:17 »
Connect a jump lead from the battery neg to an engine mount and try again.
Unfortunately, i don't have any more time to deal with it right now. I know Mark is trying to differentiate with the relay or the motor but i can hear the solenoid engage so i am almost certain its the motor. If i get a spare 5mins before i leave i will trh it.
Clicking is the clue, the solenoid is pulling in but as soon as the starter load appears the volts plummet and it drops out again.
Also, a failed chassis ground would result in engine failure as you stated, a knackered starter would not
« Reply #16 on: 23 June 2017, 13:47:21 »
At least the engine is free :y
When it cut out, did you try bumping to restart or on the starter?
Situation didn't allow for it. Too much fast moving traffic.
Fair dos,  I normally drop the clutch and use momentum to spin it over.
There's mention of retorquing engine mounts as a cure for low speed stalling... Summat to do with stressing the otherwise well supported loom :-\
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #17 on: 23 June 2017, 14:41:42 »
S$%#!  I was hoping you weren't going to suggest that.  It was in the back of my mind.  Could it cause normally working dash lights and radio to go off (when start is engaged) and come back on again?
Gaffers
« Reply #18 on: 23 June 2017, 14:44:03 »
I was shifting from 3rd to 4th at a, ahem, suitable speed for joining a dual carriageway. ::)
« Last Edit: 23 June 2017, 14:48:13 by Guffer »
Gaffers
« Reply #19 on: 23 June 2017, 14:47:56 »
The problem I am faced with is that I am flying on holibobs tomorrow morning at sparrow's fart and staying at Gatwick tonight.  I get back on a Sunday and normally I will be working the next day.  This means taking the monday off to get it fixed.
Gaffers
« Reply #20 on: 23 June 2017, 15:13:55 »
Just tried that, no joy.
« Reply #21 on: 23 June 2017, 16:15:51 »
Try also the pos to the starter terminal then (carefully)
Gaffers
« Reply #22 on: 23 June 2017, 16:43:43 »
I may have to take off the intercooler to get suitable (safe) access to do that.  Unlikely I will have the time :(
TD
  • Swindon
    • Nowt!
« Reply #23 on: 23 June 2017, 17:02:15 »
When you do get it going.....if it pops out of gear again.....that a sure sign its new gearbox time ime
« Reply #24 on: 23 June 2017, 17:14:19 »
..or an engine mount is allowing it to move around too much. ;)
Gaffers
« Reply #25 on: 23 June 2017, 17:21:15 »
This is where my thinking is headed.
TD
  • Swindon
    • Nowt!
« Reply #26 on: 23 June 2017, 17:23:13 »
I'll bow to your experience Kevin, but ive had a couple of cars that started popping out of top gear (5th) under load, they were ok in 4th.....both times new gearbox needed .....
« Reply #27 on: 23 June 2017, 18:15:52 »
I'm not saying that you're wrong, but I've also had instances where the gearbox is shifting around and it knocks the selector mechanism, which does perhaps fit the circumstances here. :y
« Reply #28 on: 23 June 2017, 18:24:10 »
Looking at the forums, the Legacy has form for loose engine mounts... If accessible, it's an easy thing to check :y
Gaffers
« Reply #29 on: 23 June 2017, 18:40:10 »
Can you send me some links :y
P.S. I don't suppose you are around the N Terminal tonight or tomorrow morning?
