Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Scoobie Legacy cut out issue  (Read 19672 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Scoobie Legacy cut out issue
« Reply #60 on: 11 July 2017, 21:45:31 »
If you're going second hand, budget for a new crank...
Which means new block, etc, etc....
« Reply #61 on: 11 July 2017, 21:53:28 »
S/H means failure sooner... newer cars are only less prone now... in time they too will show an increase in failure rate :'(
Gaffers
« Reply #62 on: 11 July 2017, 21:57:44 »
2010 engines and later resolved the issue and an apparent internal memo confirmed an issue with boring or the amount of sealant used on the caps.  But they are not common and highly sought after as you can see.
« Reply #63 on: 11 July 2017, 22:03:10 »
Fair dos... if it lasts a year, then that's $200 a month which is still less than a replacement car ;)
« Reply #64 on: 12 July 2017, 07:30:34 »
Options i have:
1 nearly new 8k
2 older but good condition with warranty 4k
3 one from a breaker. No warranty, engine already has a knock (not sure if just a lifter) 400 ish quid.
Thats ebay, internet pages and scoobie forums checked.  Although my old man has found a working block (no starter, alternator, etc) in the US for $2300 + delivery
Surely you can rebuild yourself for a fraction of that, its only a chufin Robin engine
« Reply #65 on: 12 July 2017, 08:36:54 »
Hmmm....three bearing crank on a diesel and its known to wipe out a main.....what a stunning piece of design!
Gaffers
« Reply #66 on: 12 July 2017, 09:47:58 »
Yes, I have been making use of my time in hospital to read up on other people's experiences and I wish I had found all this information prior to purchasing the car.  It's a real shame because it is a fantastic car, probably one of the best I have driven and I include the XF in that assessment.  If I can find a way of replacing the engine cost-effectively I will, but a rebuild will likely mean a new block anyway.
Pages: 1 2 3 4 [5]  All   Go Up
