Author Topic: Obd pin out  (Read 2896 times)
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Obd pin out
« on: 23 June 2017, 15:43:03 »
I made a code flasher for my volvo 850, I need to know if the pin out is the same so I dont blow it up
My plan was to add a 3 way slider switch  to swap  moduals
e46 325i se - 1.8vvti avensis liftback
Re: Obd pin out
« Reply #1 on: 23 June 2017, 20:03:39 »
Given your car is NOT OBD compliant, you might be lucky. Then again...
frostbite
    • 00' e46 325i se
Re: Obd pin out
« Reply #2 on: 23 June 2017, 20:47:44 »
What could be the worst that could happen?
I have this set to the engine but with the slider will hopefully flash the climate and gearbox
Bit I need to know which pin does what, I will try and find the volvo pin out again
Re: Obd pin out
« Reply #3 on: 23 June 2017, 21:00:30 »
Being a 'classic', Haynes will tell you...
Re: Obd pin out
« Reply #4 on: 24 June 2017, 09:40:52 »
Why not just use a paperclip. Pretty certain the 2.0l doesn't flash out to the (non) OBDII port, as it flashes to the dash instead.
Look up Paperclip test
frostbite
    • 00' e46 325i se
Re: Obd pin out
« Reply #5 on: 24 June 2017, 17:08:18 »
That was the point with the 850, but if it wont work I wont bother, I know the pedal trick works but this flashes slower and each code is flashed by pressing the button
Page created in 0.022 seconds with 20 queries.
