Author Topic: Drivers door lock  (Read 2705 times)
G.Wadling
  • Somerset
    • Omega 2.2 cdx
Drivers door lock
« on: 26 June 2017, 18:32:18 »
 Hi  I'm looking for a front drivers door lock for a 2.2 cdx petrol estate,  not having much luck so far !! .If anyone can help it would much appreciated   many thanks Gordon
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Drivers door lock
« Reply #1 on: 26 June 2017, 19:06:16 »
What do you require?
Handle
catch
barrel
dead lock solenoid
A user OMEGOD is breaking a 99' 2.2 saloon in star silver
e46 325i se - 1.8vvti avensis liftback
« Reply #2 on: 26 June 2017, 20:23:26 »
Central door locking motor?  Its likely to be the microswitch.  Look in Maintenance Guides, Kevin Wood did an excellent guide on replacing the microswitch :y
I have changed several of these switches, and in all cases, that's resolved the issue completely
(granted, I always have spares, so just replace the motor, then repair the one that came out at my leisure, before putting it back in the spares cupboard)
G.Wadling
  • Somerset
    • Omega 2.2 cdx
« Reply #3 on: 27 June 2017, 10:37:43 »
Hi thanks for the replies  the part I need is door latch mechanism ,the part you can see when the door is open  it locks onto the strike  plate not the usual suspects   , I would send a photo if could get the attachment  section to work  ps   Jon  Omegod  I tried to send you a message but your in box is full   cheers Gordon
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 27 June 2017, 13:46:08 »
Apologies for the inbox fullness  :-[ pm replied to
« Reply #5 on: 27 June 2017, 18:26:12 »
Sorry, ignore my earlier post then, I misunderstood.
One of the breakers here should be able to sort you out with a good part - this part is normally very reliable, so 2nd hand should be fine :y
