Author Topic: steering  (Read 2513 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
steering
« on: 02 July 2017, 20:00:17 »
when doing motorway speeds there is a definite shake on the steering. should  I start with a wheel balance check ?
Diamond Black Geezer
    • & a silly coupe coming...
Re: steering
« Reply #1 on: 02 July 2017, 20:27:49 »
I'd say so, yes. Start with the basics  :)
Also, just 1/100 chance (but well worth checking) - check all your wheel studs are done up...  :)
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: steering
« Reply #2 on: 02 July 2017, 20:38:28 »
Not only that, you could have a mishapen rim
I had new boots and the bloke told me one was out of shape, so got it placed on the rear, no shake and no brake pull
e46 325i se - 1.8vvti avensis liftback
omega2018
    • MercCL500 Omega2.6ManElit
Re: steering
« Reply #3 on: 02 July 2017, 23:58:01 »
shake at certain speeds which goes away when you speed up or slow down, is a good indicator that your wheels need balancing.
Re: steering
« Reply #4 on: 03 July 2017, 08:41:29 »
First of all, is it more pronounced at certain speeds? On Omega, around 40-50mph, with just wheel shake, tends to be front balancing (or damaged wheels/tyres), around 80-95mph with a shake you feel through the seat tends to be rear.
More random steering wheel wobble, often more under braking (but too random to be warped discs) tends to be front wishbone bushes.
