Author Topic: One for the networking experts  (Read 17001 times)
Taxi_Driver
Re: One for the networking experts
« Reply #15 on: 29 November 2006, 18:44:49 »
I have tried the same dns servers used on the router and the 4.2.2.1, 4.2.2.2 dns servers but it still gives the same results
Might solve the prob if you set the router to obtain DNS via DHCP
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #16 on: 29 November 2006, 18:46:58 »
Nope TD im using bulldog nowadays.
this box used to connect to BT using the old blue fish dsl modem and ran ics for the rest of the network but since I replaced the modem with a router it is just another terminal now.
TuBy's new whipping boy.
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #17 on: 29 November 2006, 18:48:02 »
hmmm ... not anything to do with the "Tunnel adapter Automatic Tunneling Pseudo-Interface" you have on that machine is it ???
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #18 on: 29 November 2006, 18:53:21 »
Router now set to auto its dns and guess what all pcs but one still connect fine :(
Sounds I dunno what that tunnelling thingy is so I dunno.
Taxi_Driver
« Reply #19 on: 29 November 2006, 18:55:23 »
I just set my laptop to use those dns servers you posted......it did get there with OO.com but was a lot slower at resolving than my isp....
Hmmm suggest you delete all the network connections except the ethernet adaptor one.....any reason as Sounds says for the other network connections??
Give it a reboot and see what happens
« Reply #20 on: 29 November 2006, 18:59:51 »
The tunnel may be some vpn connections you may have set up? for work?
If none of others suggestions work, uninstall NIC, reboot, then reinstall NIC.  Seems its using btnet servers whatever is set against NIC. So either, VPN taking priority (find out when you delete tunnels), or registry corruption has 'dangle berries'ed current settings.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #21 on: 29 November 2006, 19:01:49 »
Ok network connections shown are nic, two firewire connections for the video card and mobo firewire ports (neither are connected to anything) and a bluetooth network which doesn't give the option to delete but is disabled anyway.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #22 on: 29 November 2006, 20:17:33 »
Uninstalled any unnecessary networking stuff from windows.
Uninstalled NIC
Rebooted
system reinstalled on reboot
still getting that bloody page   :(
Any more ideas guys?
Omega-MV6
  • Calne, Wiltshire.
« Reply #23 on: 29 November 2006, 20:34:48 »
Sorry, your ISP is Bulldog, and this page is the only page you can get?
yet Ping an IP, and you get a responce... andit seems you ping a name like Omegaowners.com, and get a reply..... So the TCP/IP on the PC is fine.so it's a browsing issue.
Are you using NAT, or are your PC's directly on the net??
Sounds like HTTP requestes from that IP are being forwarded the a specific host...(normally done when you don't pay your bill)....  :P
Cheers.
Matt
« Last Edit: 29 November 2006, 20:39:38 by Omega-MV6 »
There are only 10 types of people in the world.....
......Those that understand binary, and those that don't
Omega-MV6
  • Calne, Wiltshire.
« Reply #24 on: 29 November 2006, 20:38:55 »
Also are there oany Outbound NATs on the router? Maybe one has been created in the router's moment of madness or something.
Finally aret there any Proxy server settings in your IE config?
Cheers.
Matt
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #25 on: 29 November 2006, 20:55:51 »
Cheers.
Matt
Not quite right Matt, pinging OOC should use the IP 217.155.56.220 but it pings 194.73.73.50, and any other url I try to ping gets the same ip address.
Its connected thru a router which I believe uses NAT
No outbound NATs or any other forwarding set up on router
No proxy set in browser prob also occurs with ftp proggy but can be resolved by using ip addy of site rather than name.
« Last Edit: 29 November 2006, 20:57:19 by CaptainZok »
Omega-MV6
  • Calne, Wiltshire.
« Reply #26 on: 29 November 2006, 21:06:18 »
Sorry I misread your problem.
So everything you try and do points to the same IP?
Sounds like you have a duff Transport Agent.
Get hold of "hijack this" (It's Free) run it on the duff PC, and post the output here...
Should be able to pick it up, and select the one to remove
Cheers.
Matt
Omega-MV6
  • Calne, Wiltshire.
« Reply #27 on: 29 November 2006, 21:08:30 »
Oh also what happens if you ping the other PC's on your own Subnet/Network?
Matt
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #28 on: 29 November 2006, 21:30:49 »
Logfile of HijackThis v1.99.1
Scan saved at 9:29 pm, on 29/11/2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Norton Internet Security\ISSVC.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\ctfmon.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\netdde.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\PROGRA~1\COSIDS\BIN\TbMux32.exe
C:\Program Files\HighPoint Technologies, Inc\HighPoint Storage Management Software\service\hptsvr.exe
C:\WINDOWS\System32\imapi.exe
C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
C:\WINDOWS\System32\tcpsvcs.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\WINDOWS\TWAIN_32\D66U\D066UUTY.EXE
C:\Program Files\ScanSoft\OmniPagePro12.0\Opware12.exe
C:\Program Files\Microsoft Hardware\Mouse\point32.exe
C:\Program Files\Microsoft Hardware\Keyboard\type32.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\ATI Multimedia\RemCtrl\ATIRW.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Microsoft ActiveSync\wcescomm.exe
C:\PROGRA~1\MI3AA1~1\rapimgr.exe
C:\WINDOWS\System32\rundll32.exe
C:\WINDOWS\system32\rdpclip.exe
C:\WINDOWS\system32\logonui.exe
C:\WINDOWS\system32\taskmgr.exe
C:\WINDOWS\system32\logon.scr
C:\Temp\New Folder\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
F1 - win.ini: run= C:\WESTWOOD\C&C95\INSTICON.EXE
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: WinZip IBS - {99A10100-66BB-11D4-A02A-00600818E7D8} - C:\PROGRA~1\WINZIP\wziebs.dll
O2 - BHO: Norton Internet Security - {9ECB9560-04F9-4bbc-943D-298DDF1699E1} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O2 - BHO: FlashFXP Helper for Internet Explorer - {E5A1691B-D188-4419-AD02-90002030B8EE} - C:\PROGRA~1\FlashFXP\IEFlash.dll
O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll
O3 - Toolbar: Norton Internet Security - {0B53EAC3-8D69-4b9e-9B19-A37C9A5676A7} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [Jet Detection] "C:\Program Files\Creative\SBLive\PROGRAM\ADGJDet.exe"
O4 - HKLM\..\Run: [D066UUtility] C:\WINDOWS\TWAIN_32\D66U\D066UUTY.EXE
O4 - HKLM\..\Run: [Opware12] "C:\Program Files\ScanSoft\OmniPagePro12.0\Opware12.exe"
O4 - HKLM\..\Run: [POINTER] C:\Program Files\Microsoft Hardware\Mouse\point32.exe
O4 - HKLM\..\Run: [IntelliType] "C:\Program Files\Microsoft Hardware\Keyboard\type32.exe"
O4 - HKLM\..\Run: [ATI DeviceDetect] C:\Program Files\ATI Multimedia\\Program Files\ATI Multimedia\main\ATIDtct.EXE
O4 - HKLM\..\Run: [ATIPTA] C:\PROGRAM FILES\ATI TECHNOLOGIES\ATI CONTROL PANEL\ATIPTAXX.EXE
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe /Consumer
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [ATI Remote Control] C:\Program Files\ATI Multimedia\RemCtrl\ATIRW.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\wcescomm.exe"
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~4\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Easy-WebPrint Add To Print List - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_AddToList.html
O8 - Extra context menu item: Easy-WebPrint High Speed Print - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_HSPrint.html
O8 - Extra context menu item: Easy-WebPrint Preview - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_Preview.html
O8 - Extra context menu item: Easy-WebPrint Print - res://C:\Program Files\Canon\Easy-WebPrint\Resource.dll/RC_Print.html
O8 - Extra context menu item: QuickDefine - C:\Program Files\Common Files\Microsoft Shared\Reference Titles\eddefine.htm
O8 - Extra context menu item: QuickTranslate - C:\Program Files\Common Files\Microsoft Shared\Reference Titles\edtrans.htm
O8 - Extra context menu item: Send To &Bluetooth - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\system32\msjava.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\system32\msjava.dll
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #29 on: 29 November 2006, 21:31:52 »
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra button: ATI TV - {44226DFF-747E-4edc-B30C-78752E50CD0C} - C:\Program Files\ATI Multimedia\tv\EXPLBAR.DLL
O9 - Extra button: ICQ Pro - {6224f700-cba3-4071-b251-47cb894244cd} - C:\PROGRA~1\ICQ\ICQ.exe
O9 - Extra 'Tools' menuitem: ICQ - {6224f700-cba3-4071-b251-47cb894244cd} - C:\PROGRA~1\ICQ\ICQ.exe
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM95\aim.exe
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-4017 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: @C:\Program Files\Messenger\Msgslang.dll,-61144 - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: @C:\Program Files\Messenger\Msgslang.dll,-61144 - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O12 - Plugin for .mid: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin2.dll
O16 - DPF: {00B71CFB-6864-4346-A978-C0A14556272C} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab
O16 - DPF: {1F2F4C9E-6F09-47BC-970D-3C54734667FE} (LSSupCtl Class) - https://www-secure.symantec.com/techsupp/asa/LSSupCtl.cab
O16 - DPF: {2917297F-F02B-4B9D-81DF-494B6333150B} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
O16 - DPF: {665585FD-2068-4C5E-A6D3-53AC3270ECD4} (FileSharingCtrl Class) - http://appdirectory.messenger.msn.com/AppDirectory/P4Apps/FileSharing/en/filesharingctrl.cab
O16 - DPF: {814EA0DA-E0D9-4AA4-833C-A1A6D38E79E9} (DASWebDownload Class) - http://das.microsoft.com/activate/cab/x86/i486/NTANSI/retail/DASAct.cab
O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab
O16 - DPF: {9059F30F-4EB1-4BD2-9FDC-36F43A218F4A} (Microsoft RDP Client Control (redist)) - http://laptop/tsweb/msrdp.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/msnmessengersetupdownloader.cab
O16 - DPF: {E77C0D62-882A-456F-AD8F-7C6C9569B8C7} (ActiveDataObj Class) - https://www-secure.symantec.com/techsupp/activedata/ActiveData.cab
O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - http://download.mcafee.com/molbin/iss-loc/vso/en-us/tools/mcfscan/1,5,0,4321/mcfscan.cab
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Ati HotKey Poller - Unknown owner - C:\WINDOWS\System32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Bluetooth Service (btwdins) - WIDCOMM, Inc. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: COSIDS_TB - TransAction Software, D 81737 Munich - C:\PROGRA~1\COSIDS\BIN\TbMux32.exe
O23 - Service: HighPoint Storage Management Service (hptsvr) - Unknown owner - C:\Program Files\HighPoint Technologies, Inc.\HighPoint Storage Management Software\service\hptsvr.exe
O23 - Service: ISSvc (ISSVC) - Symantec Corporation - C:\Program Files\Norton Internet Security\ISSVC.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
O23 - Service: SAVScan - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
O23 - Service: ScriptBlocking Service (SBService) - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1\SBServ.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: Symantec Core LC - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
O23 - Service: X10 Device Network Service (x10nets) - Unknown owner - C:\PROGRA~1\ATIMUL~1\RemCtrl\x10nets.exe (file missing)
